Old 09-27-2022, 10:40 AM
Funk-O-Meter Funk-O-Meter is offline
Default Problem with software licenses when buying used consoles?
If we buy second hand Profiles or SC48's, and the seller doesn't have the info for the original ILOK accounts, what issues will we encounter?
As I understand it the console should function fine, but we wouldn't be able modify the factory plugin bundle at all.
The only other issue I'm aware of is if the hard drive fails, we wouldn't be able to reinstall the software on a new drive without purchasing new licenses from AVID.
What else am I missing? Thanks!
Old 09-28-2022, 02:09 AM
Valentyn Valentyn is offline
Default Re: Problem with software licenses when buying used consoles?
I believe you should contact support for transferring ownership to your Avid account, so that you can download stuff. You're not the first in this situation.
Meanwhile you can just take an image of existing hard drive and use it in case you need to replace drive.
Old 10-21-2022, 02:07 AM
timothytomon14 timothytomon14 is offline
Hello,
How are you on this.
We are currently experiencing a faulty drive that says there's a certain dll file missing on our system32 which literally means there's is something wrong on the running os of our venue sc48.
We are eyeing to replace the drive to SSD, however, we don't have a recovery or driver disc to use since we bought this mixer second hand.
Hope you are still active on this thread.
Thank you so much in advance.
The software required to validate licenses is not running DasDangerBear Licensing & Accounts 4 05-13-2019 12:50 AM
Buying the software Rodrigo Herrera Licensing & Accounts 3 03-01-2018 08:15 PM
Transferring Software Licenses whittybeats Buy & Sell 0 07-02-2012 04:43 PM
buying TDM licenses awe General Discussion 0 05-13-2008 09:51 AM
Problems obtaining software licenses for plug-ins cheesetree General Discussion 2 08-04-2007 05:03 AM
