Closing Session excessively long
Hello,
I am a post guy and since I use multiple instances of Battery 4 (last version) my Pro Tools sessions closing excessively long (very very long). I often force to quit. Each times I rec midi or work on a session it's the same. But if I open a session and save it while I do nothing, closing time is normal. I just uninstal completely Pro Tools (trash all folders) and install 2018.4 (HD, well no, Ultimate) and it changes nothing… I run very large sessions with big routing but as I said it appears since I use Battery. Even if I hide and make inactive Battery's tracks it's the same. To normaly close Pro Tools sessions I have to delete these tracks. What can I do ? Any ideas to help me ? Thanks !
MacPro 5.1 (2 x 3.46 GHz, Twelve Core Intel Xeon) - OS X 12.7.3 - Ram 64G - PT Ultimate 2024.3.1 - HD Native Card - Avid HD Omni - Monitoring PSI Audio (surround) |
Re: Closing Session excessively long
What type of drives are you using - spinners or ssd's? Internal or external drives?
Hopefully you're not letting the drives sleep. What happens if you only use one instance of Battery 4? |
Drives are SSD for the OS and "classics" for sessions, audio, video.
And of course they never sleep. I just tested and with one instance of Battery it's ok. And for the moment my work around is : save my session, delete midi tracks, save this new session with a different name, close session and open the first (good) session, it's faster than save session and close !
I don't see how your workaround works. You save the session and THEN delete the MIDI tracks and save it with a new name? Then you go back to the first (unedited) session? How is that saving you time? And really - how long does it take to save the session with multiple Battery 4 instances? Why do you need multiple instances? Trying to understand the problem. |
You're right for my workaround, it's : save the session without closing, then delete the midi tracks and save it with a new name, close the edited session, and then go back to the first (unedited) session and open it. It is faster because closing sessions with this problem takes almost 4 or 5mn. Multiple instance of Battery correspond (for example) to footsteps for a character or foley. And there is multiples characters, and footsteps and foleys ! Hope I am clear and thanks to try to understand !
Are you keeping PT open during all this time or what? |
Ok, example :
1. Save the session 'John_Doe', don't close. 2. Delete Battery's tracks from this session. 3. Save this session with another name 'John_Doe_00' (or not, I don't care about this session) 4. Close the session And it took normal time. But forgot my workaround it doesn't work. It worked one time this morning (before I tried to explain to you) I don't know why. But what I notice now is when I delete the midi tracks it takes the same amount of time than close the session. Very very very long. When closing the session it takes time on Battery's midi tracks (Pro Tools dialogue on screen). And the same if I try to delete them
We had these problems with 12.8.2, 12.8.3, and 2018.1 (long unload times of the mixer with large midi/instrument sessions; though no issue with opening times.)
12.8.1 did not have any issues. 2018.3 and 2018.4 have not had issues. I suggest trashing everything (databases and preferences, etc) and let pro tools rebuild from scratch and then reset your preferences by hand (don't reload old/backed-0up preferences).
Pro Tools Ult 2024.3.1, HDX 2, MTRX/SPQ, RME BBF Pro + MADIface Pro • S1 x 2, Fire Max11 x 2, Dock, iPad Air5 • Mac Mini 14,12, 12 core, macOS 13.6.6 • RAM 32GB, SSD 4TB, GPU 19 core • QNAP TVS-872XT 148TB TB3 |
Unfortunately it's a fresh install of 2018.4, so ne need to trash everything. I notice this problem occured in december, don't remember the Pro Tools version, 12.8.2 if I remember correctly. But it correpond too to my heavy use of Battery. Really don't know what to do. Maybe I have to clean my system by installing a fresh version of OSX. But I am in the middle of a big production and never did this. If only I knew it works.
mines doing the same thing since I've installed Antares Auto Tune Pro.
PT Crash After Closing Boom, Save Session and Close Session | Hannibal Lecter | Pro Tools 12 | 5 | 02-02-2017 02:23 PM |
Long delay when closing and opening sessions | plaroch | macOS | 2 | 09-21-2016 09:39 AM |
PT 11.02 freezing after closing a session and opening new session | asaffulks | Pro Tools HDX & HD Native Systems (Win) | 2 | 12-17-2013 01:49 PM |
Session layout not being remembered after closing/reopening a session/Pro Tools! | DJ Hellfire | Pro Tools 10 | 1 | 12-23-2011 12:05 AM |
Too long for comfort... problems with long session files | Burton | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 1 | 07-20-2001 06:51 AM |
