Old 03-22-2001, 08:28 AM
phobia phobia is offline
Default Digi001 ADAT, Alesis ADAT Edit and Fostex VM00
Hi!
I am investigating a setup for
- Digi001
- Alesis ADAT Edit PCI Card on a PC (or MAC)
- Fostex VM2000 with ADAT I/O.
I'd like to be able to use the Fostex as an extra AD/DA for the Digi001 using its ADAT I/O and also for the ADAT Edit Card.
The computers will be moved around to different locations for different purposes but I need to know that I can connect them for audio transfers as well as for direct recording.
Sometimes a real ADAT will be hooked up.
Does anybody have a clue if this will work out? I am a bit non experienced in using this format, and then we also have the clock sync issues.
I am very greatful for any kind of tip on this.
Best Regards,
// Joakim Westman
Ex. setup.
A)
MICS --> VM200 --> AdatOut --> Digi001 AdatIn
B)
MICS --> VM200 --> AdatOut --> Aleses ADAT Edit AdatIn (on PC)
C)
Alesis Adat EDIT out --> Digi001 Adat In.
D)
Digi001 Adat Out --> Alesis Adat EDIT In
E)
CD-R of audio files imported on each host.
F) And a number of combintations where the mixer VM200 would be in between.
>>We need more time so that everything doesn't happen at once<<
Digi 002
Mbox 1
Digi001 (retired to shelf)
Asus P5K Premium v3, Q6600, 2x2GB Corsair
Tyan Thunder n3600B (S2927A2NRF)
2xAMD OPTERON 2214 2.2GHZ
Win XP Pro SP3
Old 03-22-2001, 08:30 AM
Default Re: Digi001 ADAT, Alesis ADAT Edit and Fostex VM00
Sorry 2 typo errors above.
The mixer is Fostex VM200 and nothing else.
Cheers,
// Joakim W
Digi 002
Mbox 1
Win XP Pro SP3
Old 03-22-2001, 04:19 PM
timtraynor timtraynor is offline
I use a VM200 with an ADAT
and 001 and have had no problems.
Before I got the 001 I had an ADAT
Edit card and it sucked, but everything you
describe should work fine just make
sure all your clock settings are correct.
Rock On!
Rock On!
www.backstagegear.com
Old 03-24-2001, 08:57 AM
Thanks, but unfortunately the swedish re-seller of these mixers say that they are not manufactored any more. They refer to the smaller VM 88 which is not adequate.
Does anybody know any other similar Mixers like VM200 (ADAT, connections, scene memories etc). I think Tascam has a TMD-1000 with optinal ADAT but it is a bit more expensive.
Cheers,
// Joakim W
Digi 002
Mbox 1
Win XP Pro SP3
Alesis QS7, Digi001, ADAT optical rusmooth 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 5 03-30-2004 01:59 PM
Alesis ADAT Edit with LE jeronimo 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 4 06-09-2001 01:52 AM
PT/ADAT Bridge/Fostex ADAT/USD/Beta...... Raven Pro Tools TDM Systems (Mac) 1 12-27-2000 06:27 AM
Alesis ADAT PCR on PC, Digi001 on MAC wil it work ? phobia 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 12-20-2000 08:30 AM
ADAT-Edit with Digi001 problem aquavitae 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 1 09-04-2000 08:20 AM
