Old 09-21-2014, 11:17 AM
cplaza cplaza is offline
Default mini grand & sustain pedal issue
Recorded a live Latin Jazz quartet & the keyboard's piano voice was not good, so I hooked up a midi cable to the mini grand virtual instrument, which sounds A LOT better. While mixing, I noticed that intermittently it seems that the sustain is not going off when it should. The midi sustain track shows that the pedal is in fact being released, but either the plug-in or PT 11.2 is not following the command. When repeating the same passage or phrase, sometimes it works correctly and sometimes it doesn't.
Using PT 11.2 on W7 Quad core with RME Octamic-d, RME UFX. PT performance monitor shows that CPU util is at less than 10%, memory util is at 10% of 12GB, Disk util (2TB RAID 0) is at barely above 0%. Has anyone had experience with this? And if you did, how did you fix it?
Thanks...best regards to all.
Old 09-21-2014, 07:21 PM
DC-Choppah's Avatar
DC-Choppah DC-Choppah is offline
Default Re: mini grand & sustain pedal issue
Take a look at the MIDI note events that he played and see if the pedal is being tapped right at the exact time that the note releases. If so, then that can be interpreted as:
Note Off - then sustain (which means no sustain). But when he played it, he heard a sustain.
The difference being the MIDI instrument he was hearing vs the one you are now playing back through. Different sensitivities to the race condition event. Different latencies perhaps in what you recorded vs what he heard.
Lots of ways to fix that perhaps. Shift the sustain pedal to a few ticks earlier perhaps to get rid of the race condition.
Just a thought. I recall having something like that happen once.
DC
DC-Choppah's Project Studio:
ASUS PRIME Z390-A / Intel i7 rackmount PC
Windows 10 home 64 bit
Pro-Tools 11.3.1
AIR Instrument Expansion Pack v2
WAVES Platinum plugin bundle
Tascam US-16x08 Interface
100% Analog real time monitoring 16x4
Yamaha 16 channel MG16XU Analog Monitor Mixer
Yamaha MX-88 / Novation XiO keyboards
Mackie 4-channel headphone amp
Adam A8X monitors
Blue / Shure, etc. microphones
Estonia 6' 8" Parlor Grand Piano
Yamaha Studio Drum kit
https://www.dc-choppah.com/
Old 09-22-2014, 01:15 AM
GregV GregV is offline
+1 for Choppah. MIDI note off, when timed with other events, can cause unexpected "interpretations".
Old 09-22-2014, 01:21 AM
tonwurm's Avatar
tonwurm tonwurm is offline
maybe it´s the infamous midi-sustain bug…
http://duc.avid.com/showthread.php?t=279971
workaround is to deactivate midi-merge
MP5,1 12core 3.46ghz 96GB
Ultimate HDX
https://www.youtube.com/channel/UCIA...Rnu0Jfh-YsgftQ
Old 09-23-2014, 07:05 AM
Thanks to all for the suggestions...Right now tracking in the studio for a few days & will re-address midi when I get back to mixing. fyi...Since this was live outdoors & keyboard player was only hearing the PA, he was not hearing the midi track, so this is strictly a mixing issue. I will report back at that time.
Old 09-24-2014, 04:01 AM
ChrisSimon ChrisSimon is offline
Infamous MIDI-Sustain Bug......and still there!!!!!!
Chris Simon
www.TwinMusic.de
Old 09-27-2014, 09:15 AM
Thanks. It did, in fact, to be a timing issue between the note and the release of the sustain pedal. Thanks to all!
Mini Grand issue N8ty Virtual Instruments 7 02-26-2015 08:25 PM
VI (specifically Mini Grand) Volume Level Problem / Issue guitarman6 Virtual Instruments 3 01-05-2012 10:27 PM
Sustain pedal not working with Mini Grand Gothboy Virtual Instruments 0 06-22-2009 10:31 AM
Make my sustain pedal a kick pedal dr beef 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 3 05-11-2005 12:20 AM
Make my sustain pedal a kick pedal dr beef MIDI 0 05-08-2005 10:14 PM
