Old 02-25-2014, 07:15 AM
kywildcat79 kywildcat79 is offline
Default Recording Midi to Audio
Hey guys. I've ran into a problem that I'm not sure how to fix. It seems that before it has worked fine and now for some reason I am getting this issue.
When I record a midi part, let's say 5 bars of any virtual instrument, then go to record that part to an audio file, all I get are two straight lines instead of the wave looking shape I should be getting. I still hear the file fine though.
Here's my process:
For the instrument I want to record to an audio file from I click on Blt-nOtpt1-2
Then select New Track
Then Audio Track
Then Create
Then I record the selection.
Am I missing a step? Like I said I remember doing this before and it working just fine.
Thanx for all replies and help!
Old 02-25-2014, 07:39 AM
crizdee's Avatar
crizdee crizdee is offline
Default Re: Recording Midi to Audio
Here's my process:
Then Audio Track
Then Create
You should be routing the instrument track to an audio track by routing the output of the instrument track to the input of the audio track, but it looks like you are setting the audio track input to the built in optical digital input instead.
Just set the instrument track output to a spare aux, like aux 1/2 the set the audio track input to aux 1/2 and voila
chris
Producer, Engineer,
www.ukmastering.com
Old 02-25-2014, 09:05 AM
Thanx for the reply. I tried that on a track, but the wave file still came out pretty small. Grant it, it was just a cymbal roll. I have a few other tracks in other sessions I will try this on. I have to put this track aside until my new instruments arrive anyway.
Old 02-26-2014, 05:28 AM
Don't sweat that the waveform graphic looks small. All that matters is is there enough volume for your purposes. Cymbal rolls won't necessarily show huge waveforms unless you're hitting the cymbals with a sledge hammer and have the gain turned up high
Jack
QAPLA!
Old 05-20-2014, 12:23 PM
earshatter earshatter is offline
You may have accidentally made your waveform display at a minimum. As a shortcut, try this: hold [opiton+command] and for incremental movements tap the "{[" and "}]" keys. This will make your waveform smaller and larger.
Absence of evidence is not evidence of absence...the truth is out there.
Old 05-20-2014, 01:43 PM
Glenjb Glenjb is offline
Say the volume fader of the VI is at -30db when you do this... Once you route to the audio track it will be going there at -30db. In this case I would make the new audio track, put its fader at -30db and then ALT click the Virtual instrument's fader, returning it to 0db.
Side note, instead of making a new audio track and choosing a bus you can choose "new track" from the track output menu, choose correct track type (ex. Stereo Audio Track), you can even name the track in this window which will mean the bus it automatically creates will match the track name.
Mostly same deal just quicker.
Old 05-21-2014, 08:59 AM
cplaza cplaza is offline
Default Recording Midi Using MOTU AV Timepiece
Forgive me if this seems a dumb question, as I have not worked with midi that much.
I would like to record 2 midi keyboards, one for piano and one for organ, concurrently via MOTU. Each keyboard is on a different timepiece channel and configured to transmit using a different midi channel. I configured the 2 instrument tracks to receive the respective midi channels, but either keyboard is playing to both virtual instruments. The MOTU manual doesn't seem to address what I am trying to do. Is there a way to do this that I haven't been able to figure out?
Thanks
Old 05-23-2014, 05:30 PM
Default Re: Recording Midi Using MOTU AV Timepiece
Thanks
What MOTU MIDI interface are you using? And what's your computer and operating system?
Jack
QAPLA!
Old 05-27-2014, 05:15 AM
We have a custom-built 12 GB, 3.2 GHz, Hex Core Win/7 system with Asus MB, Crucial 256GB SSD system drive, 2 1TB Hitachi drives (in RAID-0 array) as the PT 10.3.3 primary data drive, 2 2TB Hitachi backup drives. We have 3 96 I/O interfaces connected to an Avid Native HD card. For MIDI we have a MOTU MIDI Timepiece AVP-USB through which I am trying to route 2 MIDI keyboards concurrently. Each keyboard is on a different timepiece channel, and configured to send on a different MIDI channel. Can't seem to get it working the way I need, as both keyboards send to both virtual instruments. Is what I'm trying to do even possible? Thanks.
Old 05-28-2014, 04:03 AM
Perfectly possible. Did you do the routings in Timeworks? Also in PT select 'Instrument' to be shown in the Edit or Mix windows and set your MIDI routing there.
Jack
QAPLA!
Midi recording - I hear no audio, I am new to midi recording Peter Roberts MIDI 13 08-19-2007 03:15 PM
Recording MIDI as audio wedgewedge 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 5 12-05-2005 03:27 PM
When recording MIDI to Audio the audio, the audio timing isn't the same as MIDI Justin_M 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 5 11-09-2002 02:17 AM
Recording Midi to Audio rrakoczy 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 2 05-09-2002 12:18 AM
Recording Audio AND Midi to CD Steinyman 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 3 01-12-2001 12:59 AM
