Old 04-21-2013, 06:48 PM
barrel90 barrel90 is offline
Default Low Latency monitoring
I solved my recording delay while monitoring problem by changing the buffer size to 64 samples.
My question is, when recording at low latency setting, does it effect the recording quality? if so, will changing it to a higher buffer setting correct the quality?
Old 04-21-2013, 07:03 PM
cwsand's Avatar
cwsand cwsand is offline
Default Re: Low Latency monitoring
No, lower buffer settings don't affect audio quality.
Chris
Help Us Help You
Chris
Pro Tools 2024.3
Focusrite LS56
Focusrite Pro40 (2)
TC Electronic Studio Konnekt 48
Avid Artist Mix/Control
Slate Digital VRS8
Analogue Tonebuss 24 Channel
UAD-2 OCTO Core Accelerator
UAD Volt 2
macOS 10.15.7
32 GB DDR4 RAM
NVIDIA GeForce GT 740 2 GB
Old 04-22-2013, 08:17 AM
Chris
Agreed^^^with the following exception; if the computer is under powered and you start hearing clicks, pops or other obvious digital "crap" while tracking. But, having said that, I do all my recording at the 64 buffer and have no issues(but I do have a well built/tweaked computer). If I get to a stage of mix where I have lots of plugins and such that I can't run at 64, I bounce a quick ruff mix, import it to the session, line it up with the rest, make most tracks inactive and record(doing this allows me to use the 64 buffer, even though the session may have 100 tracks and dozens of plugins. It also removes latency of ADC compensating for high-latency plugins, which I normally leave inactive during tracking anyway)
Old 04-22-2013, 11:42 AM
graveleye's Avatar
graveleye graveleye is offline
It doesn't bother me now that I am used to it, but I can still hear the latency at 64 samples. It may be barely perceptible but it is there. Good thing I can live with it:)
GIGABYTE X58A-UD3R, INTEL CORE i7 960, NVIDIA GEFORCE 8400GS, WIN 7, MOTU 896mk3 HYBRID, PT 10.3.2
Old 04-22-2013, 08:01 PM
cwsand's Avatar
Yes, I can tell - especially when playing guitar. It's better than the days when I could only go down to 128. I run at 32 most of the time now and you can barely tell there's any latency. I go up to 256 for big mix sessions, but the latency isn't an issue when mixing.
Chris
Help Us Help You
Chris
Pro Tools 2024.3
Focusrite LS56
Focusrite Pro40 (2)
Slate Digital VRS8
UAD Volt 2
macOS 10.15.7
32 GB DDR4 RAM
Old 04-27-2013, 06:05 AM
Jimibrix Jimibrix is offline
What is everyone's Latency settings in the playback engine? I'm not talikng about 64, 128 or those settings, but is your Latency box checked? Delay compensation at max or min? What's a good sample rate for the latency settings? And the cache, is that 4Gb, 6Gb, etc... What's everybody's settings? Other than upping for mixing and lowering for tracking that is, I mean there are more settings in the playback engine. Streaming for audio checked?
lowest latency without "low latency monitoring" ? music project 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 6 05-11-2010 08:40 AM
Zero Latency Monitoring for 002/003 Rob Holsman 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 15 05-11-2010 08:37 AM
Low Latency Monitoring in 8.0.3 rhendee 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 7 03-08-2010 07:48 PM
Low Latency Monitoring RaySoul 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 09-05-2009 03:49 PM
zero latency monitoring!! jayq 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 3 05-26-2006 08:27 AM
