Old 12-12-2012, 03:42 AM
Jakob Clemen Jakob Clemen is offline
Default Xmon blue or black - whats the difference?
Hey Folks
I have been offered a blue D-command at a very fair price which comes with the blue Xmon. I have an Onmi Native setup and I was wondering I would benefit from keeping my Omni as monitor controller (two sets of monitors) or use the Xmon and the monitor features in the D-command.
Secondly, if anybody have some thoughts about which things to specially look for on a used D-command I would appreciate it.
Thanks in advance
Jakob
Did you talk to your talkbox today?
Old 12-12-2012, 04:22 AM
mgoorevich's Avatar
mgoorevich mgoorevich is offline
Default Re: Xmon blue or black - whats the difference?
An X-Mon utility on D command is very powerful.
But your question is not correct....
You must use your omni interface in order to output audio from the computer.
Unfortunately x-mon is analogue only.
If you test a used d-command perform a general test (several steps in utility).
Check out that all rotary controls are responsive.
Check out that all the buttons are working well.
Just my 2c
Michael Goorevich
Sound Designer
/ mixer
www.goorevich.com
PT HD⎪N v2024.3 Ultimate ● macOS Ventura 13.6.3
MacPro 7.1 (2019) 3.2GHz Intel Xeon W 16-Core ● 96 GB RAM
MTRX Studio + DADman 5.7.0.1 + MOM ● Sync HD ● AJA Kona LHi referenced by AJA GEN10 ● D-Command ES24
Old 12-12-2012, 04:30 AM
Ahh, I see - thanks
I asked because I manually shift between the two speakers on the Omni but if I understand you correctly you would use the X-mon (the blue model) instead and make the toggle on the D-command?
Old 12-12-2012, 04:39 AM
mgoorevich's Avatar
The whole monitor section on d-command will not function without xmon.
You won't be able to solo/mute your Left, Center Right e.t.c without it.
D command has a separate connection to the xmon via 15 pin cable.
I wish that D-Command could control Pro Tools outputs using its monitor section!
BTW: I think X-Mon is blue only...never saw a grey one...
Michael Goorevich
Sound Designer
/ mixer
www.goorevich.com
Old 12-12-2012, 05:20 AM
Thanks for your help.
Best
Jakob
Digidesign 16Ch. Blue D-Control with panner, scribble tray, monitor arm and Xmon. drogan88 Buy & Sell 1 04-10-2013 07:07 PM
Blue D-Command +Xmon + 192 DIGITAL neilvg Buy & Sell 1 10-19-2012 07:09 PM
Mixing Blue and Black interfaces? Guy McDude Pro Tools HDX & HD Native Systems (Mac) 4 09-08-2012 04:52 AM
Black gives way to blue cover2 brad383music Eleven Rack 3 08-20-2012 11:21 PM
WTB: D-Command Main Unit Blue w XMON efisch Buy & Sell 0 06-08-2012 08:27 AM
