Old 06-01-2011, 11:59 AM
leftalive leftalive is offline
Default Hard drive noise during read write...
... Seems as though I've got an issue with the new computer where the work drive is making a fairly constant "percolating" sound, mostly during read write, but sometimes when I'm just moving the mouse around or during screen redraws.
Anyone experience this before? Could it be an issue with the SSD system drive? The sample drive? I would assume it's a read write issue with the work drive, but I'm not sure what the fix would be.
I've tried unmounting all drives except for the system and the work drive, but it doesn't seem to make much difference.
I dragged the sample and work drives to the privacy list in Spotlight, so we'll see if maybe it was an indexing issue, but me thinks not.
PC workstation:
Windows 10 Pro
i7 12700K
RTX 2080ti
64GB DDR5 5200mhz RAM
2 Samsung 980 Pro 1TB SSDs
Samsung 850 Pro 1TB SSD
LG 34" Ultra-Widescreen monitor
Pro Tools 12.4
A loaf of bread
A stick of butter
A lot of rye whiskey
Old 06-01-2011, 12:10 PM
Craig F Craig F is offline
Default Re: Hard drive noise during read write...
I have had this kind of problem before.
I comes down to bad grounding someplace in your system.
Does the noise get recorded or is it just in the monitoring section?
Thank you,
Craig
Old 06-01-2011, 01:08 PM
It would appear to only be coming from the computer itself - as in, from inside the thing. Not being recorded, and not coming through the mains.
That's why I'd assumed it was a read/write thing with the work drive, as the system drive is ssd, so no way to make mechanical "percolating" sounds there.
PC workstation:
Windows 10 Pro
i7 12700K
RTX 2080ti
Pro Tools 12.4
A loaf of bread
A stick of butter
Read and Write drive are now playback and record is this correct evilstudios Pro Tools HDX & HD Native Systems (Mac) 2 01-01-2014 10:53 AM
Mac Hard Drive - Read with PC? soundsurfr General Discussion 3 08-29-2005 09:30 AM
PT can't find external drive to read/write! HELP!! Dan M. Tips & Tricks 2 03-08-2005 12:33 PM
Help! ProTools won't read/write to more than one drive?!?! uno1234 Pro Tools TDM Systems (Mac) 3 01-24-2001 01:00 PM
SC picking up HD write/read noise?? Jukka Digidesign Hardware & Software 5 03-09-2000 02:01 PM
