Random short "pop" noise with Pro Tools MBox
I recently got a Pro Tools MBox and it works great with my MacBook. I'm now trying to get it to work with my Windows 7 box so I can get down to just one audio interface for everything (ditching a Lexicon USB interface).
Anyway, I'm not trying to get Pro Tools to work, just going to use the ASIO driver with Ableton on the PC. On the inbound side there is a periodic (sometimes not for several seconds, then 1-2 per second for several cycles) pop noise. This noise is not present on the input signal (occurs whether anything is plugged in or not, regardless of gain setting on the MBox). It does not show up in the MBox mixer applet. It will show up in Ableton as well as in Window's "record" section under Manage Audio Devices. It is not present on the monitors. In other words, if I'm not tapping the "record stream" then it's never present. As I mentioned, this is Windows 7, 64 bit. The drivers are the latest, 1.0.19. I've tried the original drivers that came with the 8.0.4 Pro Tools CD and the results are the same. Open to suggestions as to what to look at next. I'm sure it's driver or something on my box, though I've not had this issue with my other audio interfaces, just this one, and it doesn't happen on the MBP. System Specs: SiSoftware Sandra Computer Model : Gigabyte EX58-UD4P Workgroup : WORKGROUP Host Name : bosco User : jkeene Processor Model : Intel(R) Core(TM) i7 CPU 920 @ 2.67GHz Speed : 2.8GHz Cores per Processor : 4 Unit(s) Threads per Core : 2 Unit(s) Type : Quad-Core Integrated Data Cache : 4x 32kB, Synchronous, Write-Thru, 8-way, 64 byte line size, 2 threads sharing L2 On-board Cache : 4x 256kB, ECC, Synchronous, ATC, 8-way, 64 byte line size, 2 threads sharing L3 On-board Cache : 8MB, ECC, Synchronous, ATC, 16-way, Exclusive, 64 byte line size, 8 threads sharing Computer Mainboard : Gigabyte EX58-UD4P BIOS : Award (Phoenix) F8 05/11/2009 Bus(es) : X-Bus PCI PCIe IMB USB FireWire/1394 i2c/SMBus Multi-Processor (MP) Support : No Multi-Processor Advanced PIC (APIC) : Yes Total Memory : 6GB DIMM DDR3 Chipset Model : Giga-Byte X58 I/O Hub Front Side Bus Speed : 2x 2.4GHz (4.79GHz) Chipset Model : Giga-Byte Core CPU Generic Non-Core Registers Front Side Bus Speed : 2x 2.4GHz (4.79GHz) Total Memory : 6GB DIMM DDR3 Memory Bus Speed : 2x 532MHz (1GHz) Memory Module(s) Memory Module : G.Skill F3-10666CL9-2GBNQ 2GB DIMM DDR3 PC3-10700U DDR3-1334 (9-9-9-24 4-33-10-5) Memory Module : G.Skill F3-10666CL9-2GBNQ 2GB DIMM DDR3 PC3-10700U DDR3-1334 (9-9-9-24 4-33-10-5) Memory Module : G.Skill F3-10666CL9-2GBNQ 2GB DIMM DDR3 PC3-10700U DDR3-1334 (9-9-9-24 4-33-10-5) Video System Video Adapter : ATI Radeon HD 4650 (Microsoft Corporation WDDM 1.1) (320 SM4.1, 1GB DDR3, PCIe 2.00 x16) Video Adapter : ATI Radeon HD 4650 (Microsoft Corporation WDDM 1.1) (320 SM4.1, 1GB DDR3, PCIe 2.00 x16) Graphics Processor Storage Devices Patriot Warp V3 256GB SSD 251.7GB (SATA300) : 234GB (C:) Hitachi HDT721010SLA360 (1TB, SATA300, 3.5", 7200rpm, NCQ, 15MB Cache) : 932GB (E:) LaCie 4big Quadra 3TB (SATA300) : 3TB (K:) HL-DT-STDVD-RAM GH22NS30 (SATA150, DVD+-RW, CD-RW, 2MB Cache) : N/A (D:) Logical Storage Devices disk0-vista (C:) : 226GB (NTFS) @ Patriot Warp V3 256GB SSD 251.7GB (SATA300) disk1-users (E:) : 932GB (NTFS) @ Hitachi HDT721010SLA360 (1TB, SATA300, 3.5", 7200rpm, NCQ, 15MB Cache) disk-backup (K:) : 3TB (NTFS) @ LaCie 4big Quadra 3TB (SATA300) Optical Drive (D:) : N/A @ HL-DT-STDVD-RAM GH22NS30 (SATA150, DVD+-RW, CD-RW, 2MB Cache) Peripherals LPC Hub Controller 1 : Giga-Byte LPC Interface Controller LPC Legacy Controller 1 : ITE IT8720F Audio Device : Giga-Byte HD Audio Controller Audio Device : Hightech Information System RV730XT Audio device [Radeon HD 4670] Audio Codec : ATI (AMD) AA01h Disk Controller : Giga-Byte 4 port SATA IDE Controller Disk Controller : Giga-Byte 2 port SATA IDE Controller Disk Controller : Giga-Byte JMB36X PCIE-to-SATAII/IDE RAID Controller Disk Controller : Giga-Byte JMB36X PCIE-to-SATAII/IDE RAID Controller USB Controller 1 : Giga-Byte USB UHCI Controller #4 USB Controller 2 : Giga-Byte USB UHCI Controller #5 USB Controller 3 : Giga-Byte USB UHCI Controller #6 USB Controller 4 : Giga-Byte USB EHCI Controller #2 USB Controller 5 : Giga-Byte USB UHCI Controller #1 USB Controller 6 : Giga-Byte USB UHCI Controller #2 USB Controller 7 : Giga-Byte USB UHCI Controller #3 USB Controller 8 : Giga-Byte USB EHCI Controller #1 FireWire/1394 Controller 1 : Giga-Byte TSB43AB23 1394a-2000 OHCI PHY/link-layer Controller SMBus/i2c Controller 1 : Intel 801xx/63xx SMBus Printers and Faxes Printer : Amyuni Document Converter 400 (2400x2400, Colour) Printer : Amyuni Document Converter 300 (2400x2400, Colour) Printer : PrimoPDF (4000x4000, Colour) Printer : Microsoft XPS Document Writer (600x600, Colour) Printer : HP Officejet 7300 series fax (200x200, Colour) Printer : HP Officejet 7300 series (1200x1200, Colour) Fax : Microsoft Shared Fax Driver (200x200) Network Services Network Adapter : Realtek PCIe GBE Family Controller (Ethernet, 100Mbps) Network Adapter : TAP-Win32 Adapter V9 (Ethernet, 10Mbps) Power Management Mains (AC) Line Status : On-Line Operating System Windows System : Microsoft Windows 7 Ultimate 6.01.7600 Platform Compliance : x64 Windows Experience Index Current System : 4.9 |
Urgent!Mac Book Pro 10.7.4,Mbox 2 Mini can't read the any signal,only "click" noise | TongWunFung | macOS | 11 | 10-17-2012 05:35 AM |
Urgent!Mac Book Pro 10.7.4,Mbox 2 Mini can't read any signal,only "click" noise | TongWunFung | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 2 | 09-20-2012 12:20 AM |
Random Error, missing iLok authorization for "Pro Tools 9" | ktuulu | Windows | 52 | 04-05-2012 09:53 PM |
Mbox 2 Inaudible -10dB "noise" on one channel - hardware problem? | andreuso | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 4 | 03-19-2009 10:00 AM |
Trouble with the "MBox Noise" | hooligan12 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 1 | 06-29-2003 12:12 AM |
