Go Back   Avid Pro Audio Community > Announcements > General
Old 11-16-2006, 08:52 PM
Avid's Avatar
Avid Avid is offline
Administrator
Default Pro Tools HD 7.2cs2 Updates for Mac & Windows
Available for download from the Pro Tools CS Updates quick link in Support & Downloads:
www.digidesign.com/support
Or these direct links:Pro Tools HD 7.2cs2 for Mac OS X (PowerPC) & Windows XP both contain the following:
Fixed: Reopening a Session Containing Video Files Could Cause Them To Be Overwritten (Item # 82397)
A problem with file name suffixes could cause a second video record pass to replace the first one after the session was reopened.
This would happen after recording to a "Save As," "Save A Copy" or to video tracks that had been imported to a new session, and then saving, closing, and reopening that session.
Fixed: "Auto-Write On Stop" Modes Could Improperly Overwrite Data (Item #82271)
"Auto-Write On Stop" mode (to start, to all/selection, to end) would affect any automation write, even if it had been automatched out.
Fixed: Original Timestamps of Imported Avid .WAV Files Would Be Reset Upon a Subsequent Session Opening (Item #81997)
This bug would not occur if the audio had valid soundroll timestamps in the Avid source bin.
This bug would prevent the automatic matching features of field recorder workflows in Pro Tools.
Fixed: Embedded OMF Sequences Can Play Back Incorrectly (Item #82926)
When the OMF file had been set to "Read only" on Windows or "locked" on Mac, every region played the same audio data. Attempting to re-import the OMF after the session was opened resulted in a message, "Some regions were truncated or removed from the region list or timeline because they referred to files which are too short."
Fixed: Laying Back Audio Using MachineControl Will Engage Pre-Read Mode on a Sony DVW-500 (item #81478)
Note - this occurs when using "insert" mode in the MachineControl track arming window.
Fixed: After import of a 23.976 or 29.97 OMF or AAF, Regions Could Be Incorrectly Placed on the Timeline (Item #83338)
23.976 OMF was affected
3- and 4-perf 23.976 or 29.97 OMF and AAF were also affected
Fixed: Importing and Converting an MXF Audio File to WAV via Drag and Drop will Prevent Session from Being Saved (Item #83900)
The problem would only happen when a conversion was required or forced.
The problem would not happen when using the "Import Audio" dialog to import/convert the file.
The following fix is only in Pro Tools HD 7.2cs2 for Mac OS X:
Fixed: Unintentional Timeline Selections Could Be Made While Editing (Item #76606)
This could occur when immediately moving the mouse/trackball after unclicking.
Administrator
HTML code is On
Pro Tools 7.4.2cs2 Updates for Leopard Avid Pro Tools M-Powered (Mac) 0 11-13-2008 04:53 AM
Pro Tools 7.4.2cs2 Updates for Leopard Avid 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 11-13-2008 04:53 AM
Pro Tools 6.9.2cs2 Updates Avid Pro Tools TDM Systems (Mac) 29 08-19-2005 11:01 AM
Pro Tools 6.9.2cs2 Updates Avid Post - Surround - Video 0 07-20-2005 08:45 PM
Pro Tools TDM & LE 6.9.2cs2 Updates Avid General 0 07-20-2005 08:14 PM
