Go Back   Avid Pro Audio Community > Announcements > General
Old 11-16-2006, 08:47 PM
Avid's Avatar
Avid Avid is offline
Administrator
Default Pro Tools HD 7.2.1cs2 Update for Mac Pro
Available for download from the Pro Tools CS Updates quick link in Support & Downloads:
www.digidesign.com/support
Or this direct link:
Pro Tools HD 7.2.1cs2 Update for Apple Mac Pro
Pro Tools HD 7.2.1cs2 for Mac OS X contains the following:
Fixed: Laying Back Audio Using MachineControl Will Engage Pre-Read Mode on a Sony DVW-500 (item #81478)
Note - this occurs when using "insert" mode in the MachineControl track arming window.
Fixed: After import of a 23.976 or 29.97 OMF or AAF, Regions Could Be Incorrectly Placed on the Timeline (Item #83338)
23.976 OMF was affected
3- and 4-perf 23.976 or 29.97 OMF and AAF were also affected
Fixed: Importing and Converting an MXF Audio File to WAV via Drag and Drop will Prevent Session from Being Saved (Item #83900)
The problem would only happen when a conversion was required or forced.
The problem would not happen when using the "Import Audio" dialog to import/convert the file.
Administrator
HTML code is On
Pro Tools HD 8.1cs2 Update Avid Pro Tools TDM Systems (Win) 0 10-19-2010 02:05 AM
Pro Tools HD 8.1cs2 Update Avid Pro Tools TDM Systems (Mac) 0 10-19-2010 02:04 AM
Pro Tools LE 7.3.1cs2 Update Avid 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 03-09-2007 01:44 AM
Pro Tools HD 7.3.1cs2 Update Avid Pro Tools TDM Systems (Win) 0 03-09-2007 01:33 AM
Pro Tools HD 7.1cs2 Update Avid Pro Tools TDM Systems (Win) 0 12-14-2005 01:18 AM
