Old 05-25-2004, 02:21 AM
Gods Mistake Gods Mistake is offline
Default Access Privileges/Installing problem...
Has anyone had trouble with installing NI Intakt? I got it today (after a bit of trouble) and wanted it to use Komplete 2. Upon installation, it locked up half way and said I didn't have enough access privileges to continue installation. I'm on an ibook, OSX 10.3 too, and have ProTools 6.2.2.
The full InstallerVISE prompt said -
Error creating folder
1008:9,-5000 Access denied error
WTF does this mean?
This makes no sense, as I've essentially never logged out of my computer or messed too much at all. It means I can't register or even use it for 30 days, and I really don't want to have to send it back and forth overseas (I'm in Australia) for confirmation of anything...
Has anyone had this experience with NI stuff?
P.S. I'd like to post screenshots, but can't see how?
- I am deaf -
Old 05-25-2004, 06:50 AM
Default Re: Access Privileges/Installing problem...
Doh!
Got told on another forum to do this, and it worked!
1) First trash all the Intakt files that just got installed
2) Repair Permissions (from Apple's Disk Utility)
3) Shut down then Safe Boot (i.e. boot while holding down the Shift key...takes a while, don't worry, it is verifying your HD, and then loads the OS without any non-Apple stuff)
4) Install Intakt
5) Repair permissions again.
Time to play...
- I am deaf -
...do not have appropriate access privileges ifix macOS 13 03-20-2017 12:30 PM
"Necessary access privileges"?? WTF???? Dopamine 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 11 05-22-2012 06:25 AM
Do Not Have Appropriate Access Privileges?! :( Alexander4444 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 05-20-2010 07:47 AM
Access privileges colnago 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 11-28-2004 06:39 AM
"you do not have necessary access privileges " stickleback 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 10-10-2004 09:29 PM
