Old 06-30-2019, 05:26 AM
jchan jchan is offline
Default Bounce skips the first milliseconds
Anyone else?
I'm on 2019.6 and High Sierra.
I have no red fields in the dly comp.
Dly comp enabled.
Audio track is passed through 2 aux busses which I suspect
is the cause, but I consider it a bug. A bounce shouldn't exclude anything
, unless plugins exceed the maximum dly compensation allowed.
How about the duc got PT for free...we're all just helpful beta testers..
Old 06-30-2019, 05:33 AM
Default Re: Bounce skips the first milliseconds
Just bounced out a whole album’s worth of stems, no issues. Screenshot or some sort of description of exactly what you’re doing might help.
Old 06-30-2019, 07:56 AM
sw rec sw rec is offline
Are you highlighting PRECISELY what you want to bounce, and not just bouncing the whole window? Leave a few blank seconds at the beginning of every session, highlight what you want to bounce (zoom in, hold the SHIFT key and you can fine-tune the start point.) if you’re in the habit of slamming everything all the way to the left, yeah, it’ll clip the start of the first note. It doesn’t matter where on the timeline the session starts if you do it this way, and you won’t clip off the first couple of milliseconds of the first note.
Old 06-30-2019, 08:43 AM
Bob Olhsson's Avatar
Bob Olhsson Bob Olhsson is offline
This is typically caused by a plug-in.
Bob's room 615 562-4346
Interview
Artists are the gatekeepers of truth! - Paul Robeson
Old 06-30-2019, 11:56 AM
Eric Lambert's Avatar
Some plugins don't report the proper delays (PSP's Vintage Warmer was a culprit for years). Which plugs are on those two Aux tracks?
Old 06-30-2019, 12:31 PM
Mondo Mod is another one that is completely wrong 👍
Old 06-30-2019, 12:34 PM
Thanks for your replies!
I found the bugger...
It's AGAIN sonarworks reference..
Put in last on the masters fader, bypass, bounce.. you loose some.. you win none..
Old 07-03-2019, 07:02 AM
Neale Eckstein's Avatar
Neale Eckstein Neale Eckstein is offline
I always inactivate Sonarworks before bouncing. Also, on my HDX system, if you have the reminder to bypass it enabled, it makes the bounce delay commencement quite a bit on my system.
Old 07-17-2019, 09:19 AM
This setting makes no different for me. As soon as I bypass the SW plug-in and make the offline bounce the first 23ms isnt part of the bounced file.
SW Bug?
Old 07-17-2019, 09:22 AM
JFreak JFreak is online now
Well for troubleshooting purposes, deactivate (not bypass) all plugins everywhere and have a bounce, just to check if everything is there. If nothing is missing, you know one of the plugins is causing the trouble so activate one plugin brand a time and re-bounce. After a while you will know which plugin it is.
are 3 milliseconds of latency noticeable? jcche19 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 3 11-25-2010 04:23 AM
Music Skips During Bounce to Disk Superbee Pro Tools TDM Systems (Mac) 9 04-13-2007 04:38 AM
Music Skips During Bounce to Disk Superbee Pro Tools TDM Systems (Mac) 0 04-05-2007 09:22 PM
Milliseconds????? Peter Groom Pro Tools TDM Systems (Mac) 2 02-09-2007 06:14 AM
skips after bounce aleeleota Digidesign Hardware & Software 6 06-07-2003 01:31 PM
