Old 05-28-2019, 09:07 AM
jrmintz jrmintz is offline
Default Re: HDX card not recognized
Thanks JFreak. I did do that when I reseated it. Here's what's going on at the moment: I deleted the old DigiDal.kext , but new attempts at installing the HD driver haven't replaced it. So maybe the card isn't being seen because something is preventing the driver from being successfully reinstalled. I have no idea what or why. It's just what I'm seeing.
Thanks again all for your help.
Old 05-28-2019, 09:16 AM
JFreak's Avatar
JFreak JFreak is offline
Be sure your user has admin privileges and then restart before install -- should not have problems like that
Janne
Old 05-28-2019, 01:11 PM
gearhead2010 gearhead2010 is offline
I had this same problem, digitest did not see the HDX card which means it's a driver issue, or your card is bad. I knew my card was good so... here's what worked:
If for some reason the OS blocks proper installation of the HD Driver, you can manually force it to load with the following Terminal command:
sudo kextload /Library/Extensions/DigiDal.kext
(note that you will need to enter an Administrator password to validate this command)
After running the Terminal command you may see a system message regarding a security problem, which will then be fixed by going to System Preferences > Security & Privacy and allowing the HD driver to load (which you would normally be prompted to do immediately after installing the driver).
After going to system preferences and checking the box to allow the driver to load, it worked!
Hope that helps.
gH
Mac Pro 5,1 3.46Ghz 12 Core, (5) 1 TB Evo 840, OSX 10.9.5, PT HD 12.5.2, HDX1, (4) HD I/O 16x16, (1) Lynx HILO
Old 02-22-2021, 07:06 PM
robgraves robgraves is offline
Hope that helps.
gH
I know this thread is old but for anyone having this problem, the above was the trick that finally got my Mac Pro to recognize HDX as an engine. Gearhead2010, you're a legend.
Old 02-23-2021, 08:16 AM
corp corp is offline
I had issues with OS blocking driver..........reinstall, watch security utility.
  #16
Old 01-16-2022, 12:14 AM
steven.a.williams steven.a.williams is offline
Hope that helps.
gH
Hello,
I used your Terminal command and it worked great.
I used to have a command that automatically operated whenever I started up, but unfortunately I deleted it when cleaning up startup items. The link to the avid page no longer has this command. Any idea how to do this? I can't find it anywhere. Here is that link again.
https://avid.secure.force.com/pkb/ar...__2&popup=true
Steve
HDX card not recognized in Mac Pro paulschwotzer Pro Tools HDX & HD Native Systems (Mac) 2 12-10-2018 01:45 PM
HDX card not recognized JSeamster Pro Tools HDX & HD Native Systems (Win) 14 11-14-2018 03:56 PM
HD3 3rd card not recognized dhumez Pro Tools TDM Systems (Mac) 12 12-29-2011 01:09 PM
192 not recognized from Core card, but IS from Accel Card. Advice? Mt.Everest Pro Tools TDM Systems (Mac) 5 05-24-2010 09:14 PM
DSP FARM CARD NOT BEING RECOGNIZED BY PT Hans Mues Pro Tools TDM Systems (Mac) 2 01-29-2001 06:10 AM
