Go Back   Avid Pro Audio Community > Pro Mixing > Pro Tools | S3
Old 05-10-2019, 09:49 AM
Gordon Hookailo's Avatar
Gordon Hookailo Gordon Hookailo is offline
Default Re: Plugins not following up down p; keys anymore
Originally Posted by EddieJones View Post
We removed plugin windows opening from mouse and keyboard (PT screen actions) due to overwhelming beta feedback. We do however intend to add a preference in the next release to allow this.
So upon more messing around, I've found when "edit selection move up / down" IS checked, the plug in window does change on occasion but is often showing a different track than is selected. Not good. It will also sometimes just close the plugin GUI. It seems to be random.
If you turn off "edit selection move up / down", at least you don't end up adjusting the wrong channel. But then to turn off the plugin GUI, you need to hit "shift top/back" as Sean mentioned. Thank you for that info Sean! It seems you can also close the GUI by pressing input. This slows work flow down.
I personally loved that the eq's GUI for example would follow the track selection and then go away upon hitting the Top/back button.
I guess I'll just have to press the select button on the S3 to show the current tracks plug in for now.
Rig #1:
Mac Pro 5,1 12 core 3.33ghz 32gigs RAM / 10.12.6 2) SSDs, 2) RAIDS & other drives / Sonnet USB3 Card, ESATA Card / MOTU UltraLite-mk3 Hybrid firewire or HDN PCIe card 192 IO. S3 / Dock / Control Running PTs 12.61 thru 2019.5 when needed because of bugs in each version. Eucon 19.5
Rig#2
Mac Pro 3,1 8gigs RAM / 10.6.8 Pro Tools HD3 192 / 888 Running PTs 8
Old 05-12-2019, 09:26 PM
EddieJones's Avatar
Default Re: 19.5.0.514 REL Remember bank position broken
Originally Posted by Gordon Hookailo View Post
1) Banks used to remember position of where S3 was banked. I relied on that feature and can't get it to work now.
Gordon, can you explain this a little more so I can be clear of whats needed ?
Old 05-15-2019, 10:38 AM
Hi Eddie,
In the older Eucon, where ever you had the S3 positioned bank / track wise was saved with the layout. That way, one didn't have to assign each fader for a quick recall of what tracks you wanted to come up fast on the S3. Also great because it doesn't change the on screen track positions when recalling a layout so great for a quick fix while mixing.
I used this all the time for mixing as well as getting to certain sound design tracks.
Now, I have to scroll through an insanely long list for each fader which I hardy ever do or did cause it takes so long to set up.
Any chance of getting that functionality back?
Let me know if I described it well enough for you.
Thanks!
Rig #1:
Rig#2
Old 05-16-2019, 07:40 AM
EddieJones's Avatar
This will be fixed in 19.5.1 soon
Old 05-16-2019, 08:40 AM
Yay!
Can you also fix the inconsistent behavior of GUI windows showing up? Very often Eucon seems to remember one plug in no mater what channel you attention and reopens it (usually slot A of the first plugin you open in a session). Let me know if you need a list of steps to get this to happen. It's kind of driving me nuts.
I'm sure I need to learn the ins and outs of the new functionality (which has lots of potential and I'm very happy to see you guys moving in the right direction) but right now it's pretty wonky.
Also, just FYI, the pitch II plug in automation is broken from what I can tell. Let me know if you need steps to make that show up too.
Best and thanks!
Rig #1:
Rig#2
Mix window follows bank selection broken? Cryos Pro Tools 2018 0 02-04-2018 06:08 PM
Edit/Mix follows bank selection broken…again?? ThomasHQ Pro Tools | Control 0 05-15-2016 04:40 AM
Recalling a fader bank position- Need advice icenet ICON & C|24 2 09-24-2011 11:25 PM
Relink window doesn't remember position? poly915 Pro Tools TDM Systems (Mac) 2 10-18-2010 01:11 PM
Broken Fader Bank Button andylive VENUE Live Sound Systems 2 11-16-2009 08:49 AM
