Old 08-17-2001, 08:37 AM
prefontaine prefontaine is offline
Default midi with roland keyboard
i cant seem to get any communication
between my groovesynth and protools.
ive heard of midi problems with roland keyboards. any advice.
thanks
Old 08-17-2001, 10:03 AM
Amadeu Amadeu is offline
Default Re: midi with roland keyboard
I'm using an old D50 with PTLE and I'm haven't any problem. I use the 001 Midi interface too.
What kind of Roland are you using? And What interface? Do you mix-monitorize it again in PT or are u using external mixing-monitoring?
I use to plug my the D50 audio output to the digi 001 and then I can mix it inside PT trough an Aux Input. In this way I can add reverb, plug-ins, etc
L'adversitat ens farà
forts
Old 08-18-2001, 10:10 PM
mfym mfym is offline
Do you have local on/off on the keyboard set correctly?
Do you have the midi channels on the keyboard set up properly?
In both cases, you won't hear anything until they're set right.
Hope this helps. [img]images/icons/smile.gif[/img]
Roland Midi Keyboard - setup ocelot Windows 10 08-22-2011 06:36 PM
Roland Keyboard Midi connect problem RichrdC Pro Tools M-Powered (Win) 0 01-24-2009 05:58 PM
Roland E-96 keyboard arranger gingerbreadmusic General Discussion 2 08-17-2005 11:14 AM
Anyone with a Roland XP-60 keyboard... Mr Peete 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 3 03-21-2001 09:56 AM
Midi trouble w/Roland U20 keyboard? rooster 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 08-31-2000 10:02 PM
