cannot record on my external hd when using a lap top, only on the desktop
Hi there
There is a strange thing going on here with my external hard drive I record my audio files in a USB (I believe it is 2.0, but, now, I´m not sure) hard drive wich runs on NTFS Tomorrow I´m going to make a bootleg at a gig and to save time I´ve created all the projects in a desktop. I routed all the projects to the hard drive, while I worked on the desktop and it worked just fine. Today, I connected the hard drive on the lap top I´m using tomorrow and when I launch pro tools and check the disk allocation root media folder it tells me it´s on C: now, instead of E:. When I try to change it, it simply won´t allow me to and says "Lacie is not an audio recording volume". I read on a digi hd requirements page that usb 2.0 cannot be used as a connection for recording audio, dunno why. If that´s so, why on my desktop it works fine and when I sawp to the lap top, this bizarre thing happens? |
Re: cannot record on my external hd when using a lap top, only on the desktop
Dumb luck perhaps ? ( When it comes to your desktop ) As for the laptop , it's b/c of the way the usb hub inside the cpu is structured .( at least that's what I was told but don't know for sure ) Stick to firewire . I don't know if this helps but on my laptop , it won't read my drive unless thr cpu is powered on first . If you start the drive first ( like you should ) I can only look at the files but get the same error when opening pro tools
Yea, USB is not the way to go for this, something usually winds up going wrong.
I run my Seagate external HDD through USB 2.0 and it works as smooth as silk...
It's really as simple as that.
Pro Tools 10.3.3 | HD Native | HD I/O 8x8x8 | Mac Pro 8 Core Westmere | 24GB RAM | OSX Lion 10.7.4 | API 3124 | Chandler TG-2 | UA 4-710d | Empirical Labs Distressor EL8X | Kemper Rack | |
Well my system runs fine...*shrug*
Problem solved
The prblem was I hadn´t swapped to R the drive in the worspace menu everything wen´t fine and I did record the bootleg. actually, seven bootlegs... I´ll be posting it on mediafire this week thanks everyone :) |
I doubt you're doing 48-64 track sessions, with all sorts of plug-ins.
I also doubt that it'll continure running fine. Digi doesn't say not to use USB externals just to have something to say. USB externals are nearly always problematic, sooner or later. Firewire=stable, and supported USB=unstable, and unsupported. Pretty simple equation.
Do I REALLY NEED An External Hard Drive To Record? | MetalDrummer13 | General Discussion | 13 | 03-20-2011 04:24 AM |
Anyone using external SSD to record audio | MASTERLINKSTUDIOS | Pro Tools TDM Systems (Mac) | 21 | 04-23-2010 05:36 PM |
Record/Playback on an external drive | vinyldj69 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 2 | 09-30-2008 07:51 AM |
External Drive won't record... | sheeptuf | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 2 | 08-06-2008 04:58 PM |
002r record to the external HD | mcbv | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 3 | 11-11-2007 11:46 AM |
