Multiple EQ Setting for Separate Clips on Same Track?
I have been trying to find the answer for almost an hour now and am not really getting anywhere. My apologies, as I am sure this is a redundant question.
I am working on a short film project and have a THUNDER track that will play beneath dialogue. There are separate thunder clips on this track and I need to EQ each of them a little bit differently. The only answers I have found online are "make a new track for each thunder clip" Is this standard operating procedure for such an issue? Can I not EQ each individual clip on the same track? Thanks for your time. |
Re: Multiple EQ Setting for Separate Clips on Same Track?
hi rob. thank you for your advice. i should have thought of the automation myself! alas, i am only two months into PT.
I guess I just would have thought that I could highlight a clip and EQ it. My film school uses the ancient Apple Soundtrack Pro and that is the way it works. I am quite surprised to see that this is not an option in PT. |
Why can't he just automate the eq to whatever curve he needs at the particular points of interest?
Mac Pro 6.1, E5-2690 V2 10 core 3.0G, 32gig 1866 memory, 512G PCIe system drive, 4 480G OWC 3G SSD data drives in Thunderbolt 2 enclosure, macOS 10.15.7, Pro Tools Ultimate 2020.9.1, Twin Raven MTi's, Apollo 8 TB, 2 UAD2 Satellite Octo Thunderbolt, RME ADI-4 DD, Neve 5012, 5043, Bricasti M7, 2 PCM 92's, M350, DynAudio BM6 MK 3, BM14S, a bunch of cool mics...1 damned iLok2. |
If you really need to have a different treatment on each one, I still think the separate track method is the way to go. You could route each track to the same aux if you want to have other kinds of control over all of them at once. The automation thing seems a little kludgey. I was playing around with Reaper earlier this year, and you can do this kind of clip-based stuff with that. Some nice ideas in that software--I'd rather be working in PT, though.
HD Studio, PT2022.6, UA Apollo x6, 2018 MacBook Pro, 32 Gig, Big Sur |
Does Non-HD do snapshot automation?
HP Z2 Xeon 6 Core, Blackmagic Decklink HD Extreme 3D Win10, PT ver.. Latest |
As others have said, probably the fastest, easiest way would be to duplicate the track, Make the original inactive and use an audiosuite EQ on each section. You end up with one (active) track of EQ'd thunder...
Fast and easy.
Here I am, after time not long... and thankful for the break, What I found when I got there, was that I couldn't stay away! Hobo Shave! |
Perfect solution if you can be satisfied with the settings with one go. IF the settings are constantly changing then multiple tracks would be the faster solution. Just that if you're low on DSP/CPU resources the multiple track hassle needs to be routed (bussed) to an audio track so you can record your settings to that track once you're ready.
OR...
You can just make 8 presets.... And WRITE automation to the plug/track by playing back and selecting the next preset... the EQ will jump to the preset you chose at the time you were writing automation. This does A LOT of things... like... saves on voices (# of tracks) saves on processing power (1 EQ instead of 8!), completely re doable by altering your preset and recalling the new one during write or latch.... **** You can snap the nodes to grid If you are using a tempo map to get exact downbeat....etc
-Systems Engineer, Systems and Sound Designer, Recording and Mixing Engineer Last edited by jasonthurley; 04-18-2013 at 03:01 PM. |
Moving volume automation on separate clips | Goombot | Pro Tools 10 | 6 | 04-22-2013 11:18 AM |
Fades Multiple Audio Clips - Same Track | tomsaboia | macOS | 0 | 09-11-2012 10:14 AM |
Pan L-R on multiple clips before creating Seq? | Inga | General Discussion | 2 | 04-16-2012 02:08 PM |
Tips on multiple clips | mBoxLuvr | Pro Tools TDM Systems (Mac) | 2 | 10-15-2004 09:26 AM |
Setting up a separate hardware profile? | bryanbassett | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 7 | 06-11-2002 10:26 PM |
