LFD Large Format Display ?
Has anyone used a LFD Large Format Display for pro tools hd editing?
I am thinking about monitor upgrades, and so far 2 30" LCD seems to be my best bet. I have 2 apple cinema 23" lcd's now. Maybe I should wait till the new apple LEDs 30" LCD come out. Does anyone own 1 or has anyone actually edited on a LFD? thx in advance....
MacPro 2x3GHz Quad-Core Intel Xeon, SL 10.7.2, PT HD 10, Avid HD I/O & PRE, M-Audio Axiom Pro 49, MOTU MIDi Express 128, & many synths. |
Re: LFD Large Format Display ?
My main monitor is a 27" imac(2560x1440), almost the same resolution as the 30" LCD(2560x1600). I also have 2 20" LCD's(1680x1050) off to the sides. The 27" is absolutely awesome, I don't know how I lived without it before. Add to that the cool OSX feature of holding down ctrl and using the scrollwheel to zoom in, there is nothing to worry about as far as text being too small. One of the 20" LCD's is used as a second monitor for the imac, the other is hooked to my slave system. I use synergy to be able to drag my mouse right onto it like it's part of the imac.
- John If a MIDI event triggers a sample of a tree falling and there's no one there to hear it, does it make a sound? |
Danger .... Once you go 30" you aint never wanna turn back
2016 MacBook Pro Retina | 16GB RAM | 1TB SSD | OS X Latest - PTHD 12 Latest | 4K LG Thunderbolt Display | Logic Pro 10 |
That's true
Cheers, STeff --------------------------------------- MacPro5,1 ; 6-Core Intel Xeon 3,46 GHz, 32 Gig Ram, NVIDIA Quadro K5000 with 3 displays connected OSX10.15.7 Pro Tools|HDX Ultimate 2023.6 HD I/O&192Digital&96&96i I/Os D-Command ES 4xUnitor8 & 2xAMT8 |
Additional: The Viewsonic (and any other good third party display) can be put on a VESA mount which means you can mount it on a wall mount or console swing arm. Don't think that can be done with the Apple displays of any vintage. Last edited by musicman691; 05-30-2010 at 03:58 AM. Reason: additional material |
John: Are you using Pro Tools HD on the iMac 27"? if so, how? __________________________________________________ ____ So, no one has used a LFD as of yet??? I Have own'd the Apple 30" and it's truly awesome! I have a: http://www.newegg.com/Product/Produc...82E16824005115 I use it for gaming, and I am SO happy with it! I seem to be between 2 of these LG's 30"s and 2 Apple 30"s, but there is quiet a large price difference. 2 LG's = $2320.00 & 2 Apple's = $3200.00 (using EDU discount) The apples look better, matching wise but.... but with the extra left over from the LG's I could update my video card too. so...
No, the 27" imac doesn't have a way to connect to a pcie card or chassis. The 27" imac's do allow video input though, so you could theoretically use it as a monitor for a mac pro. If you had VE pro you could then use the imac as a VI slave.
Yes, on the 27" Imac you press a couple of buttons to switch between showing what's on the Imac vs. what's on the other computer. Note that this feature is only available on the 27" Imacs, not the 21" ones.
Come On! someone has to have owned one of these????
27" 275t 1920x1200 with two wing 19" (1024x1280) in portrait which match the hight of the 27"
3 Monitor somewhat large format HD editing is great with room for VI's and plugs or other apps. Profile needs some consideration depending on your audio monitor setup. I have a 5.1 layout with the center and analog VU meters above the 27" I like the lower rez 27" for it's image is larger allowing faders and keyboard up front. Composition lab. If your close then the higher rez 27" , 30" may be your ticket. |
Large display of region number? | Markk | Pro Tools TDM Systems (Mac) | 7 | 12-08-2011 01:30 PM |
Hookup help for Large LCD display | micline | Pro Tools 9 | 6 | 11-15-2010 02:16 PM |
Large VGA Display... Whats out there.. | bo fitz | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 1 | 01-20-2006 08:20 PM |
Large format Control Surface from Digi | Lucien Gauthier | General Discussion | 2 | 06-29-2003 12:43 AM |
Display format locked | Bunting Ho | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 2 | 02-05-2002 02:50 AM |
