Old 03-19-2020, 07:40 AM
jjsoundoc jjsoundoc is offline
Default Rolling Back O.S.
My '09 Mac Pro needed to be replaced so I ordered a Mac Mini.
It was my understanding that Catalina could be rolled back to Mojave.
I sent the computer to OWC for a RAM upgrade and the O.S. rollback.
They called to say they couldn't roll it back.
Has anyone done this successfully, or sent it to someone else to do the work?
I did try to buy a mini with Mojave installed but couldn't find any.
I work in sound to pic so don't want to jump through the hoops that Catalina requires.
Thanks for any help,
JJ
Old 03-19-2020, 07:57 AM
JFreak's Avatar
JFreak JFreak is offline
Default Re: Rolling Back O.S.
Which model exactly? Go to Apple menu, About This Mac, System Report and from there tell us the Model Identifier that you can see from Hardware Overview
Janne
Old 03-19-2020, 07:59 AM
JFreak's Avatar
As far as I know all Mac Minis should be able to run with Mojave so just download installer from App Store, create a bootable USB installer (google for instructions), then wipe the hard drive and install.
Janne
Old 03-19-2020, 08:21 AM
Janne,
The computer is being shipped back to me so can't access the model identifier.
Old 03-19-2020, 08:23 AM
JFreak's Avatar
Well once you have it back you can do it yourself. Just have 16GB or larger USB stick ready
Janne
Old 03-19-2020, 08:28 AM
I'll give it a try. Surprised that OWC couldn't do it..
Old 03-19-2020, 08:30 AM
JFreak's Avatar
Too much manual work. T2 chip makes it tough to just clone a drive from old copy. Need to actually install it by hand. While you wait for your mini to arrive, you could also do some research regarding that T2 thing
Janne
Old 03-19-2020, 08:32 AM
Will do research. Thanks for your help.
John
Old 03-19-2020, 08:37 AM
JFreak's Avatar
No problem.
With that said, what you are going to do I have not done myself. But it should be possible. Worst case scenario you will do a clean install of latest Catalina and have to deal with it
Janne
Old 03-19-2020, 10:54 PM
smurfyou smurfyou is offline
I got one a month or so ago and I installed Mojave on it. Using a USB stick.
I think I did have to first go into Recovery and do a few things to allow it. I'm sorry I can't remember the specifics but plenty of info out there. Wasn't hard.
~Will
Rolling back Mitch Griffin Pro Tools 12 7 10-07-2016 01:36 PM
Rolling back jeff5x0 Windows 4 05-01-2012 06:39 PM
Rolling back firmware on SYNC HD nasher99 Pro Tools TDM Systems (Mac) 1 12-02-2010 09:41 AM
>> Rolling back and forth between PT 7.3.1 and 7.4 Howardk Pro Tools TDM Systems (Mac) 3 11-23-2007 10:40 PM
Error after rolling back to 12.5 Pro Tools 12 0 12-31-1969 04:00 PM
