#141
Re: New Mac Pro (7.1)
Indeed. If you have anything other than the base AMD Radeon Pro 580X then slot 2 for HDX1 would be blocked by a double wide graphics card in slot 1!
Dave Marsden UK |
#142
7.1-12 core, vega card, raid card
(both doublewide) HDX2 in slots 5+6 Slot 7 open HDX Cards came with correct mini Pci power to three hdx mini 4 pin. Plus TDM HDX card connector/jumpers. All running well.
(Help us Help You)<<<click here Profile-System Tracks: https://www.n1m.com/datatunesdetroit Apple Music https://music.apple.com/us/search?term=DatatunesDetroit |
#143
Another data point: clearly, if Avid plan to support HDX6, then the cards should work in any slot (except for the I/O slot, of course).
https://lukehoward.com/ |
#144
For Mac Pro 7,1 users:
Anyone noticing stuttering playback when playing off the internal SSD, either previewing audio files in Workspace or when previewing audio files in the Finder? I find I need to click, then re-click for it to play properly. Almost as though the drives are too fast and they need a second nudge to collect their thoughts... Forrester
Pro Tools Ultimate 2023.12, HDX1 Mac Studio M2 Ultra - macOS 14.2 |
#145
#146
#147
7.1 16cores waiting....... |
#148
Hey Corp, Im ordering mine on Monday. When did you order yours? Did they give you an estimate for delivery?
Pro Tools Ultimate, HDX3 & MTRX + HD MADI 7,1 MacPro, 3.2GHz 16-core, OSX 10.15 S6 M40 48-5, panners, MPM,Dolby Atmos RMU AJA Kona LHi, Sync HD www.ToolshedAudioPost.com www.TheToolshedStudio.com Certified for Dolby Atmos Home Entertainment |
#149
Any documentation on where to connect the Belkin power cable to HDX card and on to the Mac Pro 7,1 power supply?
Thanks!
PT Ultimate 2024.3 PT HDX MacPro 7,1 (Intel) 16 Core 96 GB ram macOS Ventura 13.4 Somehow, musicians are now technicians! |
#150
Just got mine yesterday
SO far my HDX card is not recognize in the system I have the card in slot 5 as the power connector I have only works in the 6 pin slot of the Mac The Slot recommended by Avid (1) has a 8 pin power connection I have order the Belkin cables to try it next Meanwhile I'm updating Catalina in case it a fix I'm also going to try reverting the card to my Sonnet Xpress thunderbolt3 to see if that works but would defeat the purpose of having everything inside one box. Also thinking of restarting the process from scratch (ie:wiping the new system )as I have migrated my system from a Mojave setup Cheers Francois
PT 2023-12 ultimate -HDX1- OSX 13.6.1- MacPro 7.1 - D-command 24- Trinnov Dmon6 |
