Old 02-06-2013, 01:41 AM
Piers Gibbon Piers Gibbon is offline
Default Replacement for Digi 003r..Focusrite Safire Pro 40..?
Have been advised by a highly trusted supplier (Martin Fletcher at HHB in London) that the Focusrite Safire Pro 40 will be a great slot in replacement for my old 003r...
My preamping is done by an Avalon so I just need broadcast quality voiceover (one mono track!) via its AD/DA and enough ins/outs to connect my isdn codec etc (see sig)
Does the DUC hive mind agree with his suggestion? Will it happily see me through PT11 eventually? Should I spend a bit more and get something more futureproof/shiny??
Why? My Digi 003r is freaking me out with flashing lights and no host light when connected to my studio MBP as detailed in sig...LUCKILY it still eventually works when connected to my old MB running PT 7.4.3...so the plan is to replace it NOW, get it mended (scrape power bits?) and then have it as a backup (so I'd like to buy something that will slot in/out easily with the 003r)
THANKS!
www.piersgibbon.com
www.soundcloud.com/piersgibbon
VOICEOVER - Avalon 737sp/Focusrite Saffire Pro 40/Neumann + Rode inside an Esmono voiceover studio (+ Source Connect, Prima LT, Sonifex TBU, Sonnox plugins)
Record: MBP 13 inch mid 2012, 2.9 ghz i7 8gig ram, PT 11, GDrive Professional Ext Hard Drive
Backup:15 inch early 2008 MBP, OSX 10.10.2
(+Windows 7 PC running Audio TX isdn and tbu codec)
Edit: PT Express 10.3.4 on 13-inch, Late 2010 MacBook Air, OS X 10.10.4
Old 02-06-2013, 11:15 PM
cwsand's Avatar
cwsand cwsand is offline
Default Re: Replacement for Digi 003r..Focusrite Safire Pro 40..?
The Pro 40 is a great unit for the price. Has nice, clean preamps and works well with Pro Tools. I had one for about a year (also to replace a 003R) and now have the 56.
Help Us Help You
Chris
Pro Tools 2024.3
Focusrite LS56
Focusrite Pro40 (2)
TC Electronic Studio Konnekt 48
Avid Artist Mix/Control
Slate Digital VRS8
Analogue Tonebuss 24 Channel
UAD-2 OCTO Core Accelerator
UAD Volt 2
macOS 10.15.7
32 GB DDR4 RAM
NVIDIA GeForce GT 740 2 GB
Old 02-07-2013, 12:39 AM
Thanks for that, good to know
www.piersgibbon.com
Old 02-07-2013, 12:53 AM
Dism Dism is offline
^ everthing he said.
I also have a 56 with no regrets. MixControl might be a bit overwhelming at first, but once you get the hang of it, it's quite useful for setting up even complex low latency monitoring.
D
a n t h e I n c r e d i b l e S o u n d M a n
"Svetlana" v1 - 4.2GHz i7, 16GB RAM, OSX 10.7.4
Liquid Saffire 56 - PT10.2 - BFD2, VCC, Duende Native, Play 3.0
_C U R R E N T-D V E R B-S C O R E:515
Old 02-07-2013, 07:16 AM
EGS's Avatar
EGS EGS is offline
A similar story here. I went from a Black Lion modded 002R to a LS56. Then I got a Pro 40 for my 2nd rig. Both units sound & work great.
Click for audio/video demo
Click for resume
Old 02-07-2013, 03:28 PM
this is great to hear, thank you
reading the Safire pro website I wondered whether this quote might mean I could use Skype as a way of being directed down the line remotely when clients don't have ISDN or source connect...
"two virtual ‘loopback’ inputs for routing digital audio between software applications"
Something I have found impossible to do on my current 003r setup
www.piersgibbon.com
Old 02-07-2013, 03:47 PM
TAPSpace TAPSpace is offline
That is definitely what that means. It has a number or really cool functions but basically it means that you can route the output of your mac back in to Pro Tools (or other daws).
Old 02-07-2013, 07:53 PM
nst7 nst7 is offline
You might want to check out the Focusrite Scarlett 18i20. It looks like it's basically a USB version of the Saffire Pro 40.
Being USB, it would be a little more flexible in regards to what kind of computers you can use it with.
Old 02-08-2013, 12:45 PM
and it's a very nice red colour too
Actually I decided to stick with firewire as that's what is already plumbed into my Esmono studio - and I hate ramming more cables through!
Oh and I also want to be able to rapidly swap between the saffire and the old 003r (once it is mended), if the saffire ever goes down - I like backups and levels of redundancy and I hate letting clients down
www.piersgibbon.com
Old 02-08-2013, 02:59 PM
dr_daw's Avatar
dr_daw dr_daw is offline
+1 on the Saffire Pro 40. I've been loving mine, I'm very happy with the sound of the pre's on it. I've used the mixcontrol loopback feature to record itunes back into PT when working on cover songs. It works great, it takes a little to get used to the mix control, but once you understand it, it is awesome.
The one drawback is that I wasn't able to get mine to play nice with my Glyph GTP 50 FW drive. This forced me to use the Thunderbolt port with a tbolt to FW adapter. I think your MBP has two FW ports though, so you might be ok. I'm usure of what external drives you're using, but just be prepared for some fiddling around if you're daisy chaining.
Good luck Piers...jealous of your Neumann and Avalon :P Still saving up over here
FBR recording - https://www.facebook.com/fromthebase...cordsrecording
@FBRrecording - Instagram
Rig
MBP 15" High Sierra 10.13.3, i7 2.6Ghz, 8Gb DDR, 750Gb 7200rpm, PT 2019.5, Focusrite Saffire Pro 40, Octopre MkII, Glyph GPT50, Avalon 737sp, AMS Neve 1073's, API 512c, CAPI 312's, DW drums, Fender Guitars/Amps, AKG, Rode, Sennheiser, Neumann U87 & KM184's, Coles 4038, Equator D5 monitors
advice/ Focusrite safire 2i2 ? drumbit Third Party Interfaces 1 05-16-2013 04:29 PM
No midi drums to liquid safire 56 bobbyrichards Third Party Interfaces 11 03-30-2013 06:15 PM
Digi 003R replacement successful VRW macOS 1 12-20-2012 11:40 AM
Focusrite Safire 56 hotstuff Pro Tools 9 0 11-19-2010 01:54 PM
003R+ rack with octopre VS Focusrite Octopre x2 through M-audio Lightbridge Sweepxcore General Discussion 12 05-24-2009 06:44 PM
