Old 10-03-2006, 10:23 AM
floatingpoint_32bit floatingpoint_32bit is offline
Default Opening v7.1 projects in LE v6.4?
Is it possible to open M-powered/LE v7.1 projects on an computer running
ProTools LE v6.4?
/floatingpoint_32bit
Old 10-03-2006, 11:03 AM
DigiTechSupt's Avatar
Default Re: Opening v7.1 projects in LE v6.4?
Only if they're saved as Pro Tools 6.x compatible from Pro Tools 7 system.
Avid Audio Tech Support
Support FAQ
Old 10-03-2006, 11:47 AM
AlexLakis AlexLakis is offline
To make it clearer, you have to select which older version of Pro Tools you wish to save the project file as on the "save as..." dropdown menu when saving your project. If you're just the mix engineer, you'll have to make sure to specify this to the person in charge of tracking the project when they initially save the project file. Didn't realize it was there for the longest time; I could've saved some money by not upgrading my M-Powered rig at home to 7. Oh well.
Perhaps there's a program that can convert the project file without needing PT 7+ to open it?
Pro tools crashing when opening projects. chiv33s Windows 4 04-27-2013 05:14 AM
Opening Pro Tools 9 Projects in Older Versions br567 macOS 3 03-09-2011 09:48 AM
Problem opening some Projects madrocks 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 3 05-29-2010 07:58 AM
PT 7 crashing when opening PT 6 projects??? JenTraz Pro Tools TDM Systems (Mac) 3 01-22-2007 08:48 AM
PTMP 6.8 opening LE projects - very slow. Eric Klinger Pro Tools M-Powered (Mac) 0 07-21-2005 08:23 PM
