Old 02-21-2019, 07:09 AM
Nicotroidemi Nicotroidemi is offline
Default How to import/convert a PT9 session ?
My PT11 doesn't open a PT9 session, which I could understand. But how can I convert or import it ? Can't find any option in menus.
Old 02-21-2019, 08:23 AM
its2loud its2loud is offline
Default Re: How to import/convert a PT9 session ?
PT 11 should open a PT 9 session just fine. I just opened a PT 7 session with PT 2018.12 and it opened fine. Except for a few plugins that weren't compatible.
Did you actually try to open the older session or did you just assume it wouldn't work?
Old 02-21-2019, 08:25 AM
The Weed's Avatar
The Weed The Weed is offline
Is the audio SDII?
Demos: brucehayward dot com
SonoBus
Source-Connect: brucehayward
Options for Remote Direction
Old 02-21-2019, 08:29 AM
side note. If the audio is SD2. You can use PT10 to open the 9 session and convert the files .wav or aiff.
If you've purchased the 9 upgrade to 11 you most likely have 10 in your Avid account since they gave everyone the triple licenses with that upgrade.
Old 02-21-2019, 07:54 PM
Thanks guys for your answers.
Yes I tried to open them but the message says Pro Tools couldn't open because file has been created in an older version. It's not SDII but .wav files in these PT9 sessions.
To be exact, on the 10 songs the producer sent to me, my pro tools opened just two of them. The 10 songs where created by the producer on the same templates.
I still can go with AAF exports but it's very limitative.
I upgraded from 8 to 11 a few years ago. I have access to PT 10 in my Avid account. I'll download and try.
I'm on a macbook pro and Mac OS High Sierra 10.13.6
Old 02-21-2019, 08:00 PM
Share the session file only. No audio. To see if it can be opened elsewhere. It might be corrupt.
Also, none of those versions of PT are compatible with High Sierra. Just an FYI.
Want to Import Wav - Not Convert Galadriel Windows 1 04-27-2012 09:37 AM
import and convert stevegalante Pro Tools TDM Systems (Mac) 2 11-13-2008 04:39 PM
convert+import ? 44.1>48 ? itz Pro Tools TDM Systems (Mac) 1 03-19-2002 09:14 AM
Import and Convert Xopher Tips & Tricks 2 05-13-2001 12:07 AM
5.1 - Where's Convert and Import?? jdh95 Pro Tools TDM Systems (Mac) 3 03-22-2001 09:46 AM
