problems w/normalizing & change gain
For some reason when I select the region to normalize my drive starts to save then stops and SDII is stuck in a loop (the same happens when I try to change gain).This is a UW SCSI drive(using PD 2940UW card). But I have no problems using my internal drive. WHY IS THIS????
Re: problems w/normalizing & change gain
Since the internal drive is working fine I think there is nothing going wrong with your sd2. Is the UW drive formatted with something different than what your using on the internal drive?
I'm wondering if this is a formatting issue- a lot of times this behavior in Pro Tools can be caused by incompatible or damaged formatting. -bm- |
Can i get Gain, HPF and +48 to follow when i change patch? | manticore | VENUE Live Sound Systems | 8 | 07-23-2008 07:28 PM |
Normalize / Change gain Question | lydde | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 2 | 04-08-2007 02:44 PM |
Normalizing problems!!! | talksik | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 1 | 09-10-2005 04:36 PM |
Change Fader gain from 6 db to 12 db | magicm | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 2 | 06-01-2005 11:00 PM |
change gain, but volume indicator doesn't move. | hitwriter | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 1 | 03-28-2005 08:05 PM |
