Old 11-20-2019, 02:14 PM
Ceeze Ceeze is offline
Default Saving session with video crashes on separate system
Hello. I've come across an issue where saving a Pro Tools (12.8.3) session from one of our recording machine that includes video(s) will cause Pro Tools to crash on a separate system sometimes. Even ones with similar based specs and Pro Tools version, but it's very inconsistent. This seems to happen more often than not when doing the "save copy in" command. Whenever it's a drag and drop from the source, the issue doesn't seem to happen. The systems that we've tried to open those sessions with have been vast and varied including Windows machines. The video codec, frame rate or container does not seem to be the issue. We've had this problem with ProRes Proxy as well as DNxHD codecs. I'm running out of troubleshooting steps, and updating the Pro Tools version and/or the OS has to be a last resort. The only workaround seems to be making a blank session and doing a session import, but having to do that across multiple sessions recorded each day is the last thing I want to spend my time doing. We have 3 recording setups at our studio with the same specs that all seem to cause this bug. Any ideas would be greatly appreciated.
Separate video drive vs. session's Video Files folder Preston Edmondson Post - Surround - Video 5 06-27-2018 08:15 AM
PT (connected with canopus ADVC)crashes when re-open video session brenny 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 03-17-2010 08:43 PM
I delete prefs and the Database open session then system crashes 8.0.1 philip888 Pro Tools M-Powered (Win) 8 09-10-2009 06:42 AM
PT 7 crashes when saving new session *FIXED* Slikkster 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 12-02-2007 06:04 AM
? saving session as/saving copy of session in surchur 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 10-05-2002 10:24 AM
