Old 05-16-2010, 04:04 AM
Ru_C Ru_C is offline
Default Transferring 1/2 inch 16 track tape. Noise reduction advice.
Hi all, i've got a job remixing something from the late 90's that was done on 1/2 inch (16 track) tape.
Unfortunately the client has no idea what machine the recording was done on originally, & hence no idea what noise reduction (if any ) was used.
If memory serves me correctly, there were four different common standards back then. Dolby B, Dolby C, Dolby S, & DBX .
Have i got that right?
I still have access to a my old Fostex G16 (Dolby C) from that era.
What problems would I face if the tape i'm transferring used a different noise reduction type, & could this be corrected in the Digital domain?
cheers
A Rig: (Studio) I7-7700k Hackintosh - OSX 10.15.7, PT Ultimate2023.6 Native PCI-e Card, AVID I/O16 Analog i/o x2, 40 fader D-Command ES
B Rig: (Home/Office). M1 Mac Studio - 64gb ram - OSX 12.7.1, PT Ultimate2023.6, HD Native Thunderbolt, Omni, Avid Artist Control
http://www.lostboysstudio.com
Old 05-16-2010, 07:58 AM
mhmh mhmh is offline
Default Re: Transferring 1/2 inch 16 track tape. Noise reduction advice.
Originally Posted by Ru_C View Post
...could this be corrected in the Digital domain?
cheers
I see no reason why it shouldn´t be corrected digitally, using hiss reducing software like Waves´ Z-Noise for instance.
You "show" Z-Noise an empty part with tape hiss only in "learn mode" and play around with the paramaters a little. I´ve been using it for years with no problems.
Mac Pro 2,4 GHz 12-Core Intel Xeon (Westmere) 32 GB RAM, OSX 10.10.5, HD I/O 16x16 analog, HD I/O 16x16 digital, 192, PT HDX2, PT HD 12.6.0
http://www.pelhamundhaas.de/index2.html
http://www.pelhamundhaas.de/vita.html
www.3-p.de
www.imglashaus.de
Old 05-16-2010, 10:03 AM
Pirate Post Pirate Post is offline
My 2Cents...
Noise reduction systems (encode/decode) are typically complimentary compression/expansion and pre/de-emphasis curves. To have any chance at reproducing your audio close to how it was intended to sound, it would benefit you greatly to do a search on the internet to discover how these systems worked, mock them up as close as you can (expanders and EQ not NR Plug-ins) and listen to what method yields the most NATURAL results.
Peter
Peter Cole - Head Pirate
http://www.beforenoonpost.com
http://www.piratepost.net
Old 05-16-2010, 11:11 AM
GlennR01 GlennR01 is offline
I agree with Peter - you won't solve the proper decoding parameters with a noise plug-in. The expansion/compression schemes not only varied from brand-to-brand, but within brand types themselves (dbx had two or more distinctly different approaches, if I recall, and neither were compatible with dolby, which had at least 4 - A, B, C & SR).
My suggestion would be to eliminate the NR schemes it couldn't be (i.e. 16 track 1/2 inch was not a pro format, likely a Fostex - so you could pretty much rule out Dolby A & Dolby SR). You might even be able to borrow or rent the proper external nr equipment and see which sounds best to you.
In this instance, google is your friend. Best of luck.
Mac Pro 2013 2.7GHz 12 Core 128GB • Mac OS 10.5.5 • PT Ultimate 2020.5.0 • PT HDX3 • 192 IO x 8 • D-Control 32 Fader • UAD2 Octo Ultimate
Old 05-16-2010, 08:58 PM
Electrox Electrox is offline
Old 05-17-2010, 12:29 AM
elicious elicious is offline
money it was dolby c.
you can test with the nr on/off switch in back of unit.
'member the fostex is -10, so switch jumpers on your interface
b.o.l.
e
e.p.s. if you're doing more than one song
keep a grip o'qtips and alkyhol
as you might need to clean after every tune...
ihatetyping
Old 05-17-2010, 12:38 AM
sean shannon's Avatar
sean shannon sean shannon is offline
For that format, if I recall, there was dbx type 1 on the Tascam MSR-16, and Dolby C on the Fostex.
Check your mix in mono.
www.mixingtheband.com
Old 05-17-2010, 05:04 PM
BobbyDazzler's Avatar
BobbyDazzler BobbyDazzler is offline
There should be pink noise (or whatever the dolby noise was), printed on the tape if it used Dolby SR Noise Reduction.
There's no way in hell you could emulate SR decoding with an expander plugin!
Old 05-17-2010, 07:23 PM
Dolby also used special tones for aligning Dolby A, so unless you know the difference, that's no guarantee its Dolby SR.
Need advice - noise reduction software sjd22 Tips & Tricks 23 05-31-2010 11:32 PM
Noise Reduction in vocal track elsterNJ Post - Surround - Video 6 05-19-2009 11:27 AM
Noise reduction advice :Rob: 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 4 04-22-2009 09:01 AM
Dubbing from 2-inch tape Bressie Tips & Tricks 1 06-06-2005 09:27 AM
1/2 inch 8 ch tape to protools fredsparky 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 7 08-17-2004 04:03 PM
