Go Back   Avid Pro Audio Community > Other Products > Pro Tools Express on Windows
Old 09-29-2014, 08:09 AM
Joel Pierson Joel Pierson is offline
Default Trying to re-install Pro tools Express
I had to re-install Windows 7 64 bit for reasons unrelated to Pro tools.
I set up the Ilok but when trying to download Pro tools, my activation code is rejected. The msg says I have already used the code.
What do I need to do to download my copy of Pro Tools?
Dell Inspiron, Windows 7 64 bit, M-Box High Performance 4x4, Pro Tools Express
Old 09-29-2014, 10:02 AM
crizdee's Avatar
crizdee crizdee is offline
Default Re: Trying to re-install Pro tools Express
Can you download from here...
http://avid.force.com/pkb/articles/d...-3-4-Downloads
As long as you still have your ilok and pro Tools express authorisation you should be able to just download the above and install and it should work.
Chris
Producer, Engineer,
www.ukmastering.com
PT Express virtual instruments wont install joebejeckel Pro Tools Express on Windows 3 01-08-2014 02:19 PM
Pro Tools Express Software - Does not Install James1234 Pro Tools Express on Windows 1 11-04-2013 03:57 AM
install pro tools express.mpkg Drayden Pro Tools Express on Windows 1 10-30-2012 09:10 AM
New Install of Protools Express Can't Read Templates Ben Dowling macOS 1 06-21-2012 10:54 PM
First install of Pro Tools 9 - Logic 9 already installed - PlugIn install questions b-pole macOS 2 08-31-2011 07:23 AM
