Old 04-26-2016, 07:31 PM
rcutz rcutz is offline
Default broken button
today i get this "broken" buttom out of the blue, in the first slot of the softkeys on the main module. First layout bank. I must say on my defense, that I`m pretty much gentle with my S6.
Is it reparable? does it have a fix? It still working, but seems faulty and i guess
that the next phase will be to it to get fully broken.
I`m totally on the support plan. How should I proceed?
pictures bellow. you can notice the buttom misaligned
best
r.
Ricardo Cutz
Re-recording mixer/sound editor supervisor.
Http://106db.com.br
Old 04-26-2016, 08:17 PM
Brandonx1 Brandonx1 is offline
Default Re: broken buttom
I think it's covered under warranty. Contact the shop where you bought the S6.
Brandon Howlett
Vibe Audio Post, Inc.
Re-recording Mixer
Custom Build CPU, HDX 1, Omni, 192 I/O Digital
S6 M10 24 fader
Satellite Mac Pro, HDNative, 192 I/0
Black Magic HD Extreme
Old 04-27-2016, 04:32 PM
Dan Smith's Avatar
Dan Smith Dan Smith is offline
Default Re: broken button
won't be the last one
Old 04-27-2016, 06:46 PM
EddieJones's Avatar
Yes this is covered so contact Avid Customer Support and they can help you.
Old 04-27-2016, 07:16 PM
Postman Postman is offline
I've had my automation module replaced twice because the same problem. My first module lasted 9 months, the second only 3-4 months. I predicted last year that these buttons would be a continuing problem. Still, I see two bits of good news now. First, Avid's support has been VERY responsive and they have shipped replacement modules to me immediately. Second, as you've discovered, it is not a total failure. The switch and LED under the button cap continues to work. A button cap may become wobbly or perhaps completely unattached but otherwise you can keep working. A possible third good bit of news, I think Avid has made a change. My third automation module arrived in February with a different implementation of those buttons. This module is like the others except the buttons are changed. They are the same size but the small window of light through each button that shines yellow, is bigger and brighter, easier to see at an angle. I really like that aspect. Each button's snap action feels better too, more crisp and predictable than before. They still do not have the crisp snap that "tact" switches usually have but they are better than my previous modules. So far my new automation module's buttons have held up perfectly while I beat on them. I am very sensitive to these changes, because I am paranoid that I'll break another one, but these are good so far.
Meanwhile though, my master module developed two broken buttons. Both can be pulled out of their holes easily. These are the same "old" style as my earlier automation modules. I am in the middle of a project and I have chosen to ignore them until later. The module functions perfectly well anyway (thank you, Avid and Gravity). A replacement will need software install and other setup so until a break comes, I will wait.
Avid will take a financial hit on this design flaw. For now, I strongly recommend that you purchase extended hardware coverage once your first year of support ends. You will need it!
system specs in profile
Music won't play. Play button flashes and Stop button lights up Mattitude 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 24 04-16-2020 03:03 PM
Broken light XLR connector and broken is iLok USB port victorbraga98 VENUE Live Sound Systems 2 09-28-2015 10:48 PM
Broken Fader Bank Button andylive VENUE Live Sound Systems 2 11-16-2009 08:49 AM
done button replaced with open button. ronoc 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 09-24-2009 11:20 AM
002 Control Surface Mute Button Broken/Stuck..! Citrin 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 6 08-26-2009 09:29 AM
