Old 01-23-2020, 03:27 PM
SomeOtherGuy SomeOtherGuy is offline
Default MTRX 8-channel card not showing in Pro Tools
I just installed a 3rd MTRX 8-channel preamp card (in addition to the two 8-channel preamp cards already there), and it's showing up in the DADman software, but in ProTools it still reads as a MTRX 16x16, when it should be 24x16. Not seeing the extra 8 channels as available in I/O.
Any help appreciated.
Pro Tools Ultimate, Avid MTRX, MOM, Mac Pro 3.5 Ghz 6-Core (2014) 64 GB RAM, Mac OS Mojave, Samsung T5 SSDs
Old 01-23-2020, 04:20 PM
creativecontrol's Avatar
Default Re: MTRX 8-channel card not showing in Pro Tools
Greetings.
I'm not sure what your particular system configuration is, however, I would recommend setting your Port Emulation to MTRX 32x32. If you are, for example, connected to a single HDX card you would configure as follows:
CONF tab in DADman: (Pro Tools HD / DigiLink)
PHD Mode: 2xPrimary
Port 1 Emulation: MTRX 32x32
Port 2 Emulation: MTRX 32x32
This would allow you to route in and out of the DADman patchbay to and from Pro Tools with 64 channels of DigiLink.
Pro Tools doesn't automagically know how many and what type of IO cards you have populated into your MTRX - only that there are X total DigiLink spigots coming in and out of the HDX or HDN engine cards.
Hope this helps.
best,
Jeff
Jeff Komar
Applications Specialist, Pro Audio
Old 01-23-2020, 05:50 PM
Thanks Jeff. My setup is Pro Tools HD Native, and I'll never use more than 8 Dante channels, so would it be better as this?
Digilink mode: Pri/Exp
Port 1 emil. MTRX 32x32
Old 01-23-2020, 06:03 PM
LukeHoward LukeHoward is offline
If you don't have any other interfaces, you can set it to Pri/Pri and both ports to MTRX 32x32 –*then you have 64 I/O to play with.
Old 01-23-2020, 06:04 PM
Will do, thanks!
FS: MTRX 2x 8 Line Input Pristine Card 1x MTRX SPQ Card antonis Buy & Sell 8 Yesterday 02:23 PM
Can't get MTRX Dante card to work... SomeOtherGuy Pro Tools HDX & HD Native Systems (Mac) 25 01-22-2020 11:53 PM
Room EQ Wizard data to MTRX SPQ Speaker Processing Card torpor Pro Tools HDX & HD Native Systems (Mac) 0 12-16-2019 07:47 AM
MTRX SPQ Card and >Fs Sample Rates BScout Post - Surround - Video 4 01-07-2019 05:21 PM
SPQ Speaker Processing Card for Pro Tools | MTRX Avid Technical Alerts 0 08-10-2018 09:24 PM
