Old 10-29-2019, 04:31 PM
belasoul belasoul is offline
Default Undo blocked
When i insert a Waves WLM or Izotope Insight2 in the Master Channel it unfortunetly happens that i can‘t use the undo function (greyed out).
Somewhere i read that it has to do with the a utomation of these Plugins which uses all available undo steps.
Anyone could tell me how to avoid that?
MacOs 10.13.6, RME Fireface UC / UAD Apollo, PT Ultimate 2019.12
Mac Pro 6.1/12-core,64GB RAM, Aja t-tap
Old 10-29-2019, 04:40 PM
Meads's Avatar
Meads Meads is online now
Default Re: Undo blocked
Since you're German as well, might that be it?
http://duc.avid.com/showthread.php?t=398201
iMac Pro
- MacOS 10.14.6
- Pro Tools U HDN 2019.6
- Avid HD Omni + HD I/O 8x8x8
- C|24 | S3 | Dock
Old 10-29-2019, 09:04 PM
Vedat's Avatar
Vedat Vedat is offline
Quiet Art Ltd.
Check your prefs-->Mixing-->Automation and see if the Include Control Changes in Undo Queue is checked.
If so, this is why the undo queue gets hammered with plugins that write automation.
Vedat
Check out WaveRider + Defaulter:
QuietArt.co.nz
Catchin' SYNC app
Old 10-30-2019, 09:26 AM
I can't speak for Insight2, but with WLM there is a parameter called Automation Warning that constantly writes automation and kills the undo cue. I have Plug-in Controls Default to Auto-Enabled turned on in Preferences>Mixing, so I manually disable that one parameter in the WLM automation enable menu when I instantiate the plugin. Hope that helps.
Scott Gatteño
Yessian
HTML code is On
Nothing but "Undo Change Control Value" in undo queue WinstonDeath Pro Tools 11 15 07-26-2016 06:59 AM
Ilok Transfers blocked roberts Licensing & Accounts 8 06-21-2015 10:07 PM
PT 7,4 blocked after launching boun 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 02-27-2008 01:34 PM
keep the fader UNDO and edits UNDO separate uno1234 Pro Tools TDM Systems (Mac) 5 12-06-2005 10:30 AM
I can't undo record audio, I CANT UNDO !!! Dither16bit Digidesign Hardware & Software 0 06-09-2004 02:53 AM
