Old 11-15-2010, 02:12 PM
robo6675 robo6675 is offline
Default Built in output sample rates
First off, PT9 seems to fantastic. Painless install and things are running great. here comes the but...BUT is it really not possible to run a 88.2 session off the internal speakers??? I'm always tracking at 88.2 and this was supposed to simplify my life by not being tethered to the 003...am I missing something or are the only sample rates I can run off the internal speaker really only 44.1, 48 and 96?
MacBook Pro (silver) 2.5 GHz Intel Core 2 Duo - 4 GB RAM - 10.6.6 - PT9 - 003 BLA sig mod
Terrarium
HD3 Accel on a PowerPC - OS 10.5.7 - PTHD 8.0cs2
(3)192/SYNC IO/CS HEDD192/Studer A27/Neve 48 Ch. VR console
Old 11-15-2010, 02:31 PM
spkguitar's Avatar
Default Re: Built in output sample rates
Sample rates are controlled by the hardware. If the hardware you are using does not support the sample rate you were using in older sessions, you will either
  1. not be able to use them
  2. have to convert the sessions to a sample rate supported by the hardware you are trying to use.
Old 11-15-2010, 02:43 PM
getz76 getz76 is offline
spkguitar is correct. The playback is determined by the playback hardware. The software is still dependent on some sort of hardware, it just does not need to be digidesign hardware any longer.
If you don't mind me asking, why 88.2kHz?
| Logic Pro 9 | Reason 6.5 | Pro Tools 10 | MOTU UltraLite mk3 | RME ADI-2 | Summit Audio 2BA-221 x 2 | MOTU 8pre x 2 |
| Mac Pro (4,1) 2.26gHz Xeon x 2 16gB OS X 10.7.4 | Macbook Pro (8,2) 2.2gHz i7 Quad 16gB OS X 10.7.4 |
Old 11-15-2010, 02:49 PM
Thanks for stating the obvious. Just wondered if there's some system settings I'm missing.
Terrarium
Old 11-15-2010, 02:52 PM
88.2 because it makes the math simpler to get down to the eventual 44.1. That being said I've never done a A/B test to see if it really makes a significant sonic difference. Maybe todays a good day to start working at 44.1 from now on
Terrarium
Old 11-16-2010, 03:48 PM
Does anyone know of it's possible to get a different sound card for my 2007 MBP? One that would do 88.2 obviously...even an express card solution would make me happier than getting an Mbox3 or apogee duet.
Terrarium
Old 11-16-2010, 04:03 PM
jeremyroberts jeremyroberts is offline
Myth
http://www.gearslutz.com/board/maste...own-44-1k.html
http://src.infinitewave.ca/
--Jeremy
[IMG] code is Off
Focusrite Saffire 56 Sample Rate Problems - Sample rates changing during start up finalcut Windows 12 02-20-2012 05:00 AM
No output from Mbox: built-in phone output only DaveSullivan 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 10-19-2006 07:03 PM
Session sample rates & Soft Sample Cell soundboy35 Pro Tools TDM Systems (Mac) 4 10-26-2003 07:11 PM
Comparing Bit-rates, Sample-rates, and convertors - Telling the difference? stoogee 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 4 05-05-2003 09:36 AM
sample rates...44.1 or 48...what do you use? donut 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 27 02-12-2002 08:14 PM
