  #51
Old 01-19-2020, 04:46 PM
Macsearcher Macsearcher is offline
Default Re: Track Folders Are Here .. !
just turn the solo safe on on the aux track, problem solved
With all due respect, there are many times where the current AUX solo safe option is frustrating.
For instance, trying to listen to a reverb return.
The VCA solo usability is the main reason that I've moved my workflow in that direction.
  #52
Old 01-19-2020, 04:51 PM
xrekcor's Avatar
xrekcor xrekcor is offline
So Track Folders will be here in 2020...... is that 2020.1, .2, .3, .4, .5, .6, .7, .8, .9, .10, .11 or .12?
Rob
MBP 15” 2018 macOS Mojave 10.14.6 Touch Bar and ID
Pro Tools 2019.12-23.# - HEAT applied, Cubase 9.5,
Yamaha TF5, UR44, BEHA4700
........and a bowl of M&M's
  #53
Old 01-19-2020, 04:52 PM
JFreak JFreak is online now
Pun taken. Last year the dot-one was postponed to dot-three first and then released as dot-five later
  #54
Old 01-20-2020, 03:06 AM
danyg danyg is offline
true
Mac Pro 12 core 3.46Ghz - 64 Gb ram - SSD 500 Gb - HD1 2T - HD2 2T - OS 10.10. - Mac Book Pro retina- OS 10.10. - SSL Alphalink convertor - Pro Tools 12 native - SSL Matrix console - Logic Pro X
  #55
Old 01-20-2020, 08:56 AM
krabbencutter krabbencutter is offline
True, but that was also because they ran into issues with the increased voice count for HDX hardware.
  #56
Old 01-20-2020, 09:02 AM
Still unresolved, by the way
  #57
Old 01-21-2020, 12:15 PM
onosendai onosendai is offline
You could do that and that's what I do, however the VCA-way is much more intuitive and it enables me able to e.g. listen to just reverb returns and work much faster with track groups, since I can work in chunks and not just in single tracks. You can create tracks groups, but depending on what you do, it's too much a hassle to set up first and the whole enable/disable thing.
In the context of Folder tracks the VCA Solo behaviour makes much more sense, so I was just curious if anyone had tested it at NAMM
i7 5820K, 32GB | Windows 10 Pro, PT 2019.12 Ultimate | RME FF802
  #58
Old 01-21-2020, 12:18 PM
We shall see soon enough..?
  #59
Old 01-21-2020, 12:26 PM
Originally Posted by Macsearcher View Post
......where the current AUX solo safe option is frustrating.
This was a sore spot for me until I concocted my way around it. I have a send in the last slot of every track. They are all set to pre-fade and set to -0 and muted. I can Ctrl-click on any of those sends(one or any combo) and the signal is routed out to a separate set of outputs. On my speaker switcher(Presonus Central Station for now), I can choose to listen to that output, instead of the main mix, or in combo with main mix on one set of speakers and the send signal on a separate set. Solved lots of issues for me
  #60
Old 01-21-2020, 01:31 PM
I keep thinking that you solved it by mixing outside the box, but you are in fact doing it in the box.
What are track folders, and what is the magic therein? jscomposer Pro Tools 2019 10 12-14-2019 06:12 PM
Feature Request - Track Folders or Trees DrFord Pro Tools TDM Systems (Mac) 8 05-29-2010 08:45 PM
track folders vikingbrother 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 05-14-2005 08:45 PM
red folders....... Chris Lambrechts General Discussion 6 11-23-2000 02:43 AM
Folders fender General Discussion 0 01-05-1999 02:07 PM
