Old 02-16-2019, 11:48 AM
MusicMadness MusicMadness is offline
Default custom actions
Hi there, I think about buying an ipad to extend by oid command 8 capabilities. Is it possible to create a layer of custom actions so I could have several buttons on a screen with my own shortcuts? I mean something like they do on this video with dock:
https://www.pro-tools-expert.com/hom...inger-workflow
And the most important: I know that the meters will disappear from c8 but will anything else actually change? Are they fully compatible with each other?
PT HD 2018.1, Mac Pro 2013, Digidesign Command 8, Focusrite Clarett 2Pre
Old 02-17-2019, 06:34 AM
Cheesehead Cheesehead is offline
Default Re: custom actions
You couldn't get the command 8 to trigger Eucon shortcuts from its surface like you can with the Dock, but you can use the Ipad to trigger hundreds of them and program your own and macros too.
PT Control on the ipad has been the single most important new feature for me in the last few years. Its incredibly useful and improving all the time.
The compatibility doc says it will run with command 8, I'm not sure whether you'll lose the metering, but everything else will still work as midi based interfaces and Eucon can co-exist happily in Pro Tools.
I'd say definitely go for it.
Make sure you check the Eucon compatibility docs for your Ipad and PT versions.
Mac Pro 7,1 16 core, OSX 12.7.3, HD-Native TB, Trinnov MC, MTRX Studio, 2xRME ADA-4, Sync HD, AJA IO XT, Avid Dock, Avid S1, PT Control, Soundflow, PT 2023.12
repetitive actions and knobs wear rcutz Avid S4/S6 10 02-10-2016 10:00 AM
How to cancel actions of Beat Detective Micleboy Pro Tools M-Powered (Win) 5 12-15-2008 11:24 PM
AES output "hit" from certain actions in 7.1cs8 BrianM Pro Tools TDM Systems (Mac) 8 08-16-2006 12:12 PM
PT7 stalls at actions like trim, record Theodor With 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 6 06-04-2006 05:31 PM
custom 192 i/o Pietari Koskinen Pro Tools TDM Systems (Mac) 2 06-09-2002 09:20 AM
