Go Back   Avid Pro Audio Community > Pro Tools Software > Pro Tools | Intro Discussion
Old 08-16-2015, 08:16 PM
DeceivedMusicProTools DeceivedMusicProTools is offline
Default A way to make equalize volume? Help!
It's a little hard to explain, so I'll try and explain it the best way I can.
Instead of putting in notes on the MIDI Editor, I play my MIDI keyboard when recording. The problem is, I can't play the notes the same volume as other notes I play, and some notes turn out soft or loud on the MIDI Editor. Is there anyway I can play the notes all the same volume? This would really help me as it would be easier for editing and it would sound much better, than having some parts sound lower or louder in volume.
Old 08-17-2015, 12:07 PM
AlexLakis AlexLakis is offline
Default Re: A way to make equalize volume? Help!
You have at least two easy options. You can either:
Quantize MIDI velocity on input using real-time MIDI settings...
OR
Record as normal, then switch the Instrument track to "velocity" view, then select all, raise up all the velocity events to 127, then move them back down to whatever velocity suites your needs.
Old 02-01-2019, 09:58 AM
andrewyonda andrewyonda is offline
Thank you! This saved me a ton of time!
How Do You make Sectors match Volume? kingsknight Windows 1 03-16-2011 08:07 PM
Make network drive a performance volume? bakerja Pro Tools M-Powered (Win) 7 11-05-2006 02:33 AM
Not a Valid Audio Volume? how do u make it that? Eparker 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 15 10-26-2004 08:46 PM
How do you make a "Playback Volume?" SteveGarman Pro Tools TDM Systems (Mac) 1 09-09-2004 01:35 PM
How to make alternate Volume Playlists? Ale Pro Tools TDM Systems (Mac) 17 08-03-2003 03:26 AM
