ordering the allan system this week
hi everybody.. im ordering the allan system this week.. i know i posted that a few weeks ago.. but i decided to wait until after the holidays because the guy that was going to assemble it for me ended up going out of town.. ive got my shopping cart full at newegg.com and i just wantt o make sure.. before i click on order. that everythign is correct.. because a few of the items dont match up EXACTLY to what was in teh post... i know they might be the same thing.. just a number or letter different here or there. i dont know..
EVERCASE E4252-AB (BEIGE) 10-bay Case Retail*** Truly Screwless ATX MID Tower Case, Intel P4 / AMD, Front USB 2.0 w/ 1 Side Case Fan & 2 Removeable HD cages. Specifications: Driver Bays:External: 4 X 5.25" and 2 X 3.50". Hidden: 4 X 3..50" (2 screwless removeable HD Cages) Sytem Board: ATX (Up to 12" x 9.6") Expansion Slot: 7 Slots Standard Fans:1 x 8 cm Fan (Left Side) Optional Fans:1 x 8 cm Fan (Front) + +1 x 8 cm Fan (Rear) No Power Supply more info> N82E16811127014 $22.00 $22.00 Fan - Case Enermax Adjustable 8CM cooling fan (BLUE). Manual adjustable fan speed, 1000 RPM ~ 3000 RPM. 2-ball-bearing clear fan, chromed fan guard, 3pin to 4pin adaptor. Retail Box. Please see images. more info> N82E16811999010 $7.00 $7.00 Fan / Cooling Device - CPU Thermaltake VOLCANO 9 CoolMod, Copper base inserted, SMART & SILENT. Retail. For AMD Athlon XP up to 2800+ and Intel Socket 370 & AMD Socket 462. Specifications: Supported Socket type: 370 and Socket A/462 80x80x25 mm fan. Heat sink 80x80mm & 77.3mm tall. Air Flow: 20.55 CFM at 1300rpm & 75.7 CFM at 4800rpm. Instructions for Installation MUST be followed correctly. Mfr's P/N: A1455 more info> N82E16835106019 $28.00 $28.00 Floppy Drives MITSUMI D359M3 FDD 1.44MB 3.5INCH - OEM Specifications: Connector: 34-pin Floppy cable Standard Connector. Modes: HD(1.44MB) Supports: Dos, Windows 3.1, 95/98 NT3.51 and 4.0 2DD(720kb) Supports: Dos, Windows 3.1, 95/98 NT3.51 and 4.0 more info> N82E16821103104 $9.00 $9.00 Hard Drives WD WESTERN DIGITAL EIDE HARD DRIVE 20GB 7200RPM MODEL # WD200BB -Caviar OEM, DRIVE ONLY Specifications: Size: 20 Gigabytes Interface: IDE ULTRA ATA100 Seek time: 8.9ms RPM:7200 Cache 2MB OEM(Drive alone) 1 Year Manufacturer Warranty --* Works With PC & Mac *-- more info> N82E16822137116 $69.00 $69.00 WD WESTERN DIGITAL "SPECIAL EDITION" 80GB 7200RPM EIDE HARD DRIVE MODEL # WD800JB - OEM, DRIVE ONLY Specifications: Size: 80 Gigabytes Interface: IDE ULTRA ATA100 Seek time: 8.9ms RPM:7200 Cache 8MB OEM(Drive alone) 3 Year Manufacturer Warranty --* Works With PC & Mac *-- more info> N82E16822144122 $108.00 $108.00 Memory (System Memory) Crucial Micron 512MB 64x64 PC2100 DDR RAM, 184-Pin, CL=2.5-Unbuffered 2.5V, 6-Layers CT6464Z265 Requires DDR supported Motherboard - Lifetime Warranty. more info> N82E16820145005 $128.00 $128.00 Power Supplies ENERMAX EG365P-VE(FMA). 350W Power supply for AMD K7 & Pentium4. Meet AMD K7 and Intel ATX +12V 1.1 and ATX 2.03 version (Pentium 4 fully support). Ultra cooling design: one 9 cm fan intake heat and one 8 cm fan exhaust heat. Fan Speed monitored by M/B & Adjustable. 9cm Thermal Control Fan. Retail. more info> N82E16817103415 $58.00 $58.00 (it dosent say that this is a dual head video card? is it? i wanna make sure cause eventually id liek to go with two monitors) Video Cards ATI OEM RADEON 7500 64MB SDR DVI/CRT/TV BULK Specifications: GPU:ATI RADEON 7500LE MEM: 64MB SDRAM, 128-bit memory Maximium memory Interface :3.2GB/s with 200MHZ SDR. Ports:15-pin VGA ,- S-Video/composite , Standard DVI (Flat Panel Display) Bus Interface: AGP2X/4X 3D Acceleration Features: CHARISMA ENGINE, HYPER Z technology, PIXEL TAPESTRY architecture, VIDEO IMMERSION technology, Integrated Transformation, Clipping and Lighting Max 3d Res: 2048x1536 OEM BULK (comes with driver) Powered By ATI, Manufactured by Sapphire more info> Cd Burner Lite On 40X12X48 CDRW Model: LTR40125S-Full OEM Specifications: Recording 40X(6000KB/sec) Z-CLV (20X, 24X@8min, 32X@18min, 40X@53min) Re-writing 12X High-Speed (1800KB/sec) CLV Reading 48Xmax (7200KB/sec) CAV (20X~48X) Interface : ATAPI-E/IDE, support up to Ultra-DMA Mode2, 33.3MB/sec Buffer Memory Size: 2MB Access Time : 80ms (typical) SMART-BURN® technology Underun protection, MTBF : 70'000 Power On Hours with 25% Duty (thats the closest match to the cdburnere listed.. i know its a bit slower.. but most of the time i go to a cd recorder anyway so i dont need that much speed) here is teh closest match for a motherboard i could find at newegg. is this the same thing? will it work also?. .i think it dosent have raid or firewire. which wont be a problem cause im using a digi 001 and not any outboard drives or anything Asus VIA A7V333 KT333 Chipset ATX Motherboard Retail Boxed AMD Athlon XP Ready, C-Media CMI-8738 6-Channel Speaker Onboard Sound. ASUS C.O.P. (CPU Overheating Protection), Support DDR333 (PC2700) **ATA133** USB 2.0 Ready, Asus Q-FAN (Variable Fan Speed Control) 5 x PCI 1 x AGP4X 3 x DDR DIMM Sockets. Max 3GB PC2700/PC2100/PC1600 DDR, **NO RAID Model#: A7V333 Special Free FedEx Saver Shipping Detail Specs - Product Link - Chipset Info (limit 5 per customer) -See It! (image count 4 ) -Price Alert (N82E16813131413) Return to Service (avg rating out of 42 voters) (28) $103.00 and here is the closest chip i could find AMD Athlon XP 2000+/266 FSB Processor CPU - OEM 2000+/ 1.67GHz, AX2000DMT3C The AMD Athlon XP processor with QuantiSpeed architecture powers the next generation in computing platforms, delivering extra performance for cutting-edge applications and an extra-ordinary computing experience.world's highest overall performing PC processor. Specifications: CPU: 1.67 GHz Type: 2000 XP Cache: 256K BUS: 266MHz Socket A (PGA) OEM (Processor Only) more info> N82E16819103323 $75.00 $75.00 i know its a bit slower.. but slower dosnet bother me too much so long as track count and plugins and STABILITY are still there? or maybe theres another suggestion? will the the athlon 2000 have a lower track count or less stability than the 2400? (which they dont seem to have in stock right now).. also.. could i ge tthis one right now .. and if im not happy with it.. upgrade to a different one later? also. just gonna go with a cheap-o keyboard and mouse. thanx everybody! let me know if this is allright! [img]images/icons/smile.gif[/img] larry.
The Farm Recording Studio |
Re: ordering the allan system this week
looks good. having a slower cpu won't affect the stability of your machine. and the 2000 isn't THAT much slower than the 2400. only about 300mhz slower, so you'll see similar results.
Jeremy Forbis |
do you really want "truly screwless"? i never saw or used a "truly screwless" case, but it seems to me that it might vibrate some... i like screws...
also, that ATI 7500 is dual head.
i love my apple iPhone! |
Hank,
go check out thread See this thread Phil has described why you should go for the A7N8X system and 2 sticks of 512 or 2 sticks of 256 vs 1 512 stick. Furthermore, I too will be purchasing a mix of Allen' + Phil's recommendations. You can see what I found on newegg yesterday. The A7N8X system is available from newegg, BUT, they say not until tomorrow. Go to url Newegg's 2800 and I found you lite on at new egg on page 2, 2 down form the 48x12 liteon 48x24 let me know how it goes, I am waiting for the 2800, but as Phil points out, newegg only sells with approved mobo, fan, etc, which most are on the "allen/phil 002 racing machine"...
Kevin 002 XP2700 A7N8X 1g ram; 20/80 WD |
THANX all!
i hope it works out .. i just figure since i need a home pc i might as well upgrade my pro tools rig and just put my old one in my house... i bet this system will smoke too! keep reading good stuff about it.. actually had an asus motherboard on an older computer of mine and it was just the most amazing system ever i only worry about one thing. i had a cd recorder hooked up to the back of the digi 001 card.. spdif and upgraded to 5.3 and xp a while ago.. it caused all sorts of problems and so i went back to 5.1 and win 98. was that just a glitch in the earliest versions of 5.3? or a glitch in my computer?? .. also. .will i have to download 5.3 again? or is there a space on the website i can order the upgrade (rhetorical question i guess, since ill look.. i just wanted to make the point that my music store didnt know what i was talking about when i asked for the upgrade.. even though the website did say to ask your "digidesign retailer for the upgrade") oh and as for the case.. i have a pretty cool tower that my existing pc is in... its sturdy as hell and has lots of room and locks and stuff (some sort of server tower)... i might have my system put in that and my old computer put in that new case.. if it all dosent fit or it ends up being too much of a hassle. its not that big of a deal cause the case was fairly cheap.. and ive read some suggestions about these liquid cooled cases.. sounds more like a car.. mechanics i can understand, not computers... so make it sound like a car and im usually sold thanx again all keep in touch.
Your system sounds fine but i have two suggestions if you are going with the XP2000 chip.
Check out www.quietpc.com and have a look at 2 things, first, the flower cooler its fine for up to XP2000+ and its quiter than the volcano 9 Then have a look at their silent 300w power suply its also very quiet. i swaped my standard PSU and my volcano 9 for these things and it made a huge difference to how quiet my system was, and having a quiet PC for audio is very important. [img]images/icons/grin.gif[/img]
Audio Engineer/Musician/Producer |
Ordering a PSU for Control 24 | sim2so 2 | ICON & C|24 | 1 | 03-10-2011 08:48 PM |
Bought an LE8 system this week: Sucker or Shrewdie? | joethfc | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 9 | 11-05-2010 09:01 PM |
Ordering PT8 (as download) | JR_NL | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 1 | 12-24-2008 12:01 PM |
C-24 & MASTER 2 Buss Allan Smart Compressor Insert | John Pisciotta | ICON & C|24 | 0 | 10-24-2007 02:10 PM |
Ordering Custom G4's Anyone? | net4chuy | General Discussion | 7 | 08-14-2000 09:53 AM |
