  #131
Old 08-03-2019, 05:21 AM
K Roche's Avatar
K Roche K Roche is offline
Default Re: NVMe upgrade for Mac Pro 4.1/5.1 Mojave
Originally Posted by ghostwriter View Post
Using Pro Tools today. Crash, crash, crash.
Not so happy anymore.
Do I have this correct ,,, you are/were using one of the two drives in the Crest adaptor as your boot drive and PT is on that drive ?
So I am wondering if the PT difficulty is indicative of the transfer issue you were having moving files between the two drives ?
System :
Studio - Avid Carbon interface , PT Ultimate 2023.12 Mid 2020 (intel) iMac 27" Ventura 13.2 .1
Mobile - 2021 14 " MBP M1 Pro PT Ultimate 2024.3.0 --Sonoma 14.4
Enjoy the Journey
.... Kev...
  #132
Old 08-03-2019, 08:12 AM
Ghost In The Attic's Avatar
Ghost In The Attic Ghost In The Attic is offline
PT was always on the boot drive, which is blade/drive #1 on the Crest adapter. I had the sessions on the same drive. It crashed. So, I moved sessions to the second SSD on the Crest to see if they would run better from there. Same crashes.
Edited for clarity.
Retro 176 (pair), Pultec EQP-1A (pair), Germanium Comps (pair), BAE 10DC (pair), Distressor (pair), Manley Vari-Mu, Sta-Level, Zener, SSL Fusion, SSL FX G384, API 2500, LA2A, 1176, Bricasti, Massive Passive, Anamod ATS-1, Eventide H3500, TC 2290, Yamaha D5000, PCM92, PCM70... Amps, Amps & More Amps.
  #133
Old 08-03-2019, 08:14 AM
I have erased both ssd drives and am starting over again from scratch.
Got to give it one more chance.
  #134
Old 08-03-2019, 09:30 AM
K Roche's Avatar
PT was always on the boot drive. I had the sessions on the same drive. It crashed. So, I moved sessions to the second SSD on the Crest to see if they would run better from there. Same crashes.
Hummm interesting
So I get PT being on boot drive, the question I am asking is are you using one of the 2 SSD blades/drives on the Crest as your boot drive ?
And I am asking for me, because my boot drive is the SM951 and will remain the boot and PT application drive.
And so I will be using the two different EVOs on the Crest as my PT session storage drive on one of the EVO's and my FCPX projects storage drive one the other EVO. In other words replacing having those sessions and projects on the two HDD as per my system list in my sig line. And hoping I will not have any crash issue with this arrangement
System :
Enjoy the Journey
.... Kev...
  #135
Old 08-03-2019, 09:45 AM
Hummm interesting
Yes, I am booting from one of the SSD blades/drives. #1 is the one I am using. #2 is also glitchy as a boot drive. Maybe I received faulty 970 evo blade/drives, I can’t check them to see, as Samsung only supports Windows software to check their products.
  #136
Old 08-03-2019, 10:41 AM
Yes, I am booting from one of the SSD blades/drives. #1 is the one I am using. For some reason I can’t use #2 as a boot drive. Maybe I received a faulty 970 evo blade/drive, I can’t check it to see, as Samsung only supports Windows software to check their products.
Can you swap the positions of the 970's? If the problem follows the switch there's your answer - it's the 970. If it stays the same then the problem is with the card. Could be firmware or if there's surface mount parts on the card one of them might be cracked and you'll never see that - take it from someone who's dealt with more than their fair share of cracked surface mounts.
Jack
QAPLA!
  #137
Old 08-03-2019, 12:12 PM
Thank you. I misspoke in my previous post and changed it. I have booted from both 970 evo ssd drives.
I have done as you suggested and both 970s crash. I am pulling this adapter and returning it. I wish someone could recommend an adapter that would run one 970 at 3000. I know I can install one and get it to run at 1500, but 3000 would sure be nice. I have searched everywhere and l can’t find an adapter for one blade only two.
  #138
Old 08-03-2019, 03:49 PM
You should grab any single straight (non switched) card and verify both SSDs work.
Not sure if there is a x8 PCIe lane single M/2 adapter card, by the time somebody uses a PCIe Switch on the card it may be the economics and number of lanes on the chipset makes that suboptimal.
I would try swapping the switched card for another identical one and see.
Thanks for posting reports about problems you are seeing on DUC.
And to confirm you have 970 Evo and not the problematic 970 Evo Plus right? The problems withe Plus should have been addressed with a firmware update (always check the firmware is up tp date on any SSD before using them).
  #139
Old 08-03-2019, 05:49 PM
Yes, 970 Evo, not the plus.
We must be on the same page, I actually have a single non-switched card arriving tomorrow so I can test to see if the 970s both work the same, although at half the speed. I could swap out the switched adapter for another, but I will see how tomorrow’s test of the 970s goes first.
How do you check if the firmware is up to date though on a Mac?
Samsung magician is Windows only. As is every firmware utility tool that I can find for testing NVMe drives.
Thanks.
  #140
Old 08-03-2019, 11:47 PM
Mac System report, drive/firmware version should be listed under NVMExpress. But AFAIK there is no 970 Evo Firmware updates... there is the critical update for the 970 Evo Plus. https://www.samsung.com/semiconducto...ownload/tools/
You are not missing a lot with not having Magician. I'd like it on Mac, if Samsung would pull their head out their asses on how to do and support quality application software. And there are low-level barriers to what they could do on Mac, and just the size of the Mac market for SSD upgrades making it worthwhile... (so no breath holding)
Mac Pro 2012 -should upgrade to Mojave? Zak7 macOS 5 06-04-2019 07:51 AM
Mojave? hanksinclair Artist Series 3 05-03-2019 03:19 PM
New 8th Gen i7 with NVMe m.2 SSD spock999 Pro Tools 2018 26 02-22-2018 11:47 PM
Bootable Thunderbolt case for NVMe drives (Samsung 950 etc) propower General Discussion 1 10-27-2016 04:11 PM
Intel SSD NVME/PCIe Porn Darryl Ramm General Discussion 0 04-03-2015 02:02 PM
