Re: Shift + control + click on track name doesn't bank on 1st fader?
I posted a facebook message on the S6,S3 users group and got this reply. Looks like someone has it working. He's on the latest Eucontrol, Mavericks 10.95 and PT 12.5.2 Looks like it's something that broke in Protools some time after 12.5.2. Please see attached screenshot of conversation. Here is a link to the page as well. I see that you are a member but I am not able to message you there. I will try to get him to pop in on this forum. Best, Les https://www.facebook.com/groups/1623030397985977/ |
I just tested this with PT12.4.0 HD on my MacBook, OS 10.10.5 and Eucon3.7 with the latest firmware on an S3. No luck.
Thanks Les and Eddie to keep searching. Let me know if there's anything more I can do to help. Again today I've been missing this feature so much working with a large complicated session. |
Oh, well.
I thought that it seemed a bit too good to be true. |
I suspect that this worked when we were using HUI to control PT...easy test if anyone wants to try ;-)
Hey folks,
I know that Eddie is working on a solution for this for a future release but in the meantime. If any of you own Keyboard Maestro, I have a bit of a workaround for you. I've created a macro but I can't attach it here. Please email me at [email protected] and i'll be happy to send it to you. Only works with Keyboard Maestro. Hover your mouse over a track name in PT in the mix or edit window and hold down CNTRL/OPT and press ESC. The macro is clearing all selections first and then clicking on the track that you are hovered over. As we know, clicking on a track to the right of any selected track will not affect the faders on the S3. This essentially clears the cache and allows a fresh selection that starts at and spills from the far left fader. This won't work if you already have all tracks highlighted. If they are, option-click to clear all selections first. |
#16
it still works on d-command, d-control and digi003. (12.8.2) |
#17
The Mix/S3 are HUI controllers! and that's how they controlled PT before EUCON was implemented in PT.
In PT disable EUCON and set up HUI control. In the EUCON Control panel/pref add PT as a HUI controler. |
#18
For clarity. Okay, I've disabled Eucon in the PT peripherals window. How do I set up HUI control? in the Midi Controllers tab? the S3 is not listed. This shows up in Eucon prefs on my mac as Hui on midi ports 1-4 but how do I set this up from there? |
#19
If you have PT setup in the EUCON prefs and can see midi ports listed then in PT you need to add them in peripherals.
Check out this old guide I found online, at the end...http://connect.euphonix.com/document...Setup_v2_6.pdf |
#20
Thanks Eddie.
I'll give this a shot but I'm assuming that running it this way would mean losing all eucon functionality. It would also default to six character names in the OLED. |
EQ3 control+shift click option for band pass broke | crizdee | Pro Tools TDM Systems (Mac) | 4 | 11-11-2015 01:32 AM |
Eucon 3.1 bug with McMix: Shift-Fader doesn't work | DhyanMikael | Artist Series | 5 | 12-24-2013 04:50 AM |
Control 24 dead fader bank | Fix | ICON & C|24 | 2 | 10-13-2012 10:08 PM |
MC Control - bank shift 4 channels instead of 8? | KristianNielsen | Artist Series | 6 | 08-21-2012 12:12 PM |
Fader bank shift changes on screen location | The Tonic Room | ICON & C|24 | 3 | 07-29-2008 10:10 AM |
