Go Back   Avid Pro Audio Community > Pro Tools Hardware > Pro Tools HDX & HD Native Systems (Win)
Old 07-17-2013, 09:10 AM
DAWgEAR's Avatar
DAWgEAR DAWgEAR is offline
Default Recording timing / late recording issue resolved
In response this thread
http://duc.avid.com/showthread.php?t=341242
about recording timing errors, I ran the test described in post #31 of that thread and experienced a consistent delay of the recorded material (my post #44 and some after that one).
Not wanting to hijack that thread further, I am posting the resolution to my issue here in hopes that it may help someone else.
It turns out that my issue was unrelated to the issue being discussed in that thread and was due to pilot error on my part: if users of an HD Omni are using one of the designated Monitor outputs to perform a loopback test, the recorded material will not be delayed compensated. This is mentioned in the HD Omni Guide on p. 29 in italics: "With HD OMNI, Delay Compensation isnot supported on assigned Monitor outputs. Delay Compensation is only supported on physical outputs not assigned to a Monitor path".
The solution is to not use a monitor path when performing such a test or, if Outputs 1-2 are assigned to monitor, use Outputs 7-8 mirrored to the TRS jacks instead for purposes of testing. Once I acknowledged this, my tests were dead-on sample accurate.
Thanks to everyone who offered suggestions and help.
Forgotten lesson (re-) learned on my part: read the manual first!
Pro Tools HD Native 2023.12 | HD Omni | iMac Pro 10-Core 3.0 GHZ - 64 GB - 2 TB - Vega 56 | Ventura 13.5 | Sonnet Echo Express SE II for PT HD Native PCIe and UAD 2 Quad PCIe card | Avid Dock and S1
MP 9 Recording; Timing Issue.. alchemical.dream Pro Tools M-Powered (Win) 1 05-01-2012 11:47 PM
PT9 win7x64 44 samples late recording MikeLip Pro Tools 9 0 11-07-2010 05:29 AM
003 latency issue with SPDIF.Guitar is actually recording late! tonx 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 3 12-13-2009 04:14 PM
Timing issue when recording audio from MIDI tracks Gothboy 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 06-16-2006 07:42 AM
