Yamaha Motif XF series
I'm thinking of buying the XF8 for my live gigs, and I also wonder how it would work in the studio. Has anyone tried to connect it to a CPU for streaming into PT via FW?
Is it possible to increase the sampling time? 6min 20 sec @ 44.1 isn't very much.
Re: Yamaha Motif XF series
wonder how it would work in the studio. Has anyone tried to connect it to a CPU for streaming into PT via FW? Not sure this will work. It won't in PT8 at all, but might work in PT9.
Is it possible to increase the sampling time? 6min 20 sec @ 44.1 isn't very much. Look in the manual and see if you can add memory I love my es8 so I can only imagine that the XF model should a be great studio keyboard
I often prefer to ask users. They know what's what. Thanks.
Using firewire ASIO with PT 11HD. Works like a charm. It also has Hui control.
ProTools 12 HD Pro Tools 10 HD3 Nuendo 11 Ableton 9 Avid Omni HD Avid 8*8*8 HD X 2 D-Control ES 32 Channel Native Instruments Maschine Studio TC Electronic PowerCore *2 UAD-2 Universal Audio 1176 LN Universal Audio 2-LA-2 Universal Audio 2-610 Neve DPX Supermicro X10DAI Dual Xeon E5 v4 Win 10 64 128GB Ram |
I asked one of the interns here and they tried on one of our keyboards and I got the answer that you can use it several times up until the 6.20 min is full. You can edit and cut and paste so it can't be a one shot deal We hardly use it but as far as I heard it's a fine piece of gear. Christopher
I have an XF and absolutely love it. Of course I'm old school and just go USB in and midi. The sounds are very nice and once you hook it up as a slave it follows tempo changes in PT, etc. I love what I do with it as a complimentary instrument in the studio as well as a master for all of my VIs.
A Rig: MacBook Pro Spring 2013, 2.8Ghz I7, 16GB RAM, OSX Mavericks 10.9.4, PT 11.2, MBox Pro 3, Glyph GT 050 Qx3 1.5 TB drives Thunderbolt-FW400, Presonus Faderport. 10 REMOVED! B Rig:MacBook Pro Spring 11, 2.33 GHz I7, 16GB RAM, OSX Mavericks 10.9.4, PT 11.2, MBox Pro 3, Glyph Portagig 62 portable 1 TB drive Firewired with 400, Presonus Faderport. 10 REMOVED! I am the main songwriter/performer for Midwest Whitetail, Cabela's Deer Nation, Spring Thunder, and Northern Waters Series! Last edited by jryser; 07-18-2014 at 05:16 PM. Reason: spelling error |
The XF, likes its older brother the XS makes a nice MIDI controller for PT. Its my main keyboard in my set up. I use the FW for all things MIDI plus, you can use it as an alternate ASIO hardware interface. Doing that will allow you to record audio directly from the XF to an audio track in PT. (Or multiple tracks at once, ie an XF performance or a multi-tracked song on the XF. You can transfer up to 14 mono and 1 stereo at once, or 8 stereo, or any combination thereof. You just set the outputs of the XF accordingly. You will need to set up the audio I/O in PT to recognize the audio inputs from the FW when you use it that way.
Of course, depending on your interface, you can just send the audio out of the XF directly to PT audio tracks through your usual interface. You can send out either a mono, a stereo or up to 4 outputs (ie, each track in a performance can have a sep audio output from the XF). Very versatile. Also, the controllers map nicely to PT tracks as well...PB, MW, aftertouch, velocity etc. And with a ton of great sounds on board, PLUS the amazing editing capabilities..it is one mean keyboard for live or studio use.
"Never believe anything you hear in a song." Tyrion Lannister, Game of Thrones Owner: Dragon Rock Productions LLC |
We'll see what I end up with. I've just blown my savings on HDX and the HD I/O, so a new master keyboard is pushed back again. Quote:
Yeah, I still consider the XF. My current master keyboard only has pitch bend and modulation, and the mod is just a short-travel upward movement on the pitch bend, which I absolutely hate. Great to hear more about the XF, and how it works. Thanks again.
PT 9 and Yamaha Motif XS | DonaldM | Pro Tools 9 | 3 | 12-11-2010 05:56 PM |
M-Box, and Recording Yamaha Motif MIDI with Motif Voices | chuckm | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 2 | 06-30-2007 07:29 AM |
Using Yamaha Motif with PT 7.3.1 | dfwdrummer | MIDI | 1 | 04-09-2007 07:40 AM |
Yamaha motif | c3kings | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 1 | 02-04-2006 08:25 AM |
Yamaha Motif 6 + 001 5.2.1 on OS9? | nuke | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 3 | 07-07-2003 09:48 PM |
