Go Back   Avid Pro Audio Community > Pro Tools Software > Pro Tools | Intro Discussion
Old 07-29-2020, 08:40 AM
krysto4g krysto4g is offline
Default Error message
Could not complete your request because Assertion in "E:\ Code\ 238949\ ProTools\ AAE\ Source\ AAX\ CFicAAXWidget.cpp", line 994.
How do I resolve this error?
Old 07-29-2020, 08:51 AM
JFreak's Avatar
JFreak JFreak is offline
Default Re: Error message
Hi, welcome to the community.
Please take a look at the Help Us Help You page linked on the forum header.
Janne
Old 07-29-2020, 08:54 AM
And look at https://avid.secure.force.com/pkb/ar...t-cpp-line-822
But as Janne is pointing to you have to tell folks here much more about what your setup and what you are doing. In this case details about your Playback Engine/interface device and drivers you have installed.
Old 07-29-2020, 09:05 AM
OK the laptop is HP Omen 15.x the audio driver is Realtek SST for I/O ASIO 4 all is installed. Windows 10x OS I wasn't able to record a mono audio track and was looking for a solution - I must have pushed a wrong button and misconfigured Pro Tools First,since it won't load and gives me the error message above. If you need any more info let me know - thanks.
Old 07-30-2020, 07:03 AM
junkgear's Avatar
junkgear junkgear is offline
Make sure you have ASIO4ALL set up properly.
You can watch this tutorial video from the forums own Benoni on how to do this.
Once ASIO4ALL is properly configured, try holding down the N key while PTF loads, which will force the playback engine to display and allow you to choose your audio device.
If that doesn't work, then like the others said, we will need more specific information about your system and exactly what you are doing when you get the error to be able to offer any kind of help.
Thanks,
Will
Will
System Details
Pro Tools 11 activation error-licensing service not running error message Seismic Sound Windows 5 03-23-2015 05:35 AM
error message DAE error-6006 tad3219 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 1 01-03-2011 07:17 PM
error message during installation error 2147213312 pianovasano Pro Tools M-Powered (Win) 1 08-31-2010 07:52 AM
Does anyone know what this error message means. ERROR DAE 9060 boabyd23 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 08-18-2009 11:41 AM
A Message But Not An Error Message RichrdC Pro Tools M-Powered (Win) 3 01-27-2008 06:57 PM
