MIDI Noob... Playing virtual instruments simultaneously?
Hey gang...
I want to demo some songs with the band in my project studio. I have a DD65 drum controller (MIDI in and out), and a Roland A-37 (MIDI In, Out A, Out B, and Thru). I have a Midiman MIDI to USB interface, which works beautifully with both controllers. I want to use them simultaneously, the DD65 to trigger EZ Drummer, and the A-37 to control the Bosendorfer 290. I have the instrument tracks set up, and receiving MIDI signal and producing audio, but I can only get them to trigger simultaneously or not at all. I'm BRAND NEW to MIDI, so I know I'm the issue here :). How do I set up my gear to chain correctly into my machine, and set up my channels so that one is triggered by the DD65, and the other is triggered by the A-37? Any help would be greatly appreciated. Thanks! -Liam |
Re: MIDI Noob... Playing virtual instruments simultaneously?
So, it turns out that on a cryptic page in the back of my owner's manual for the DD65, it says that the default MIDI output channel for the device is channel 10. A brief read through of other issues on the DUC gave me an idea where to find MIDI channel assignments in PTLE, and a little trial and error has me up and running - A-37 on Channel 1, DD65 on Channel 10. And all's right with the world.
And even though I helped myself this time around, you guys are STILL the best. -L |
As I understand your question:
PT allows you to specifically assign a MIDI device/channel to an instrument. To do so, select VIEW -> EDIT WINDOW and make sure INSTRUMENT is checked. Now on each track, click on the top button and select the MIDI device you want to control this instrument. The top button is MIDI INPUT and the next button is MIDI OUTPUT. Busch. |
Hey Busch...
Now, that I DIDN'T know (that one was In and one was Out). And I'm sure that'll come in handy as I further confuse myself :). I appreciate the reply, and the knowledge. Thanks! -Liam |
Some virtual instruments not playing back | Eric.Yeung | Windows | 3 | 06-08-2012 03:01 AM |
MIDI track playing several Virtual instruments | d2pc | Pro Tools 9 | 1 | 09-05-2011 03:46 AM |
noob questions about virtual instruments. | graveleye | Tips & Tricks | 7 | 04-18-2011 05:39 PM |
Playing Virtual Instruments Problem | jaxsun23 | Virtual Instruments | 0 | 11-04-2009 12:10 PM |
Playing Virtual Instruments | jaxsun23 | Tips & Tricks | 9 | 01-02-2009 08:01 AM |
