  #31
Old 04-14-2019, 10:06 AM
LesPaulGtr LesPaulGtr is offline
Default Re: Avid Artist Mix Replacement touch-sensitive rotary encoders
Hi All,
I'm having a similar issue with my Euphonix MC Control. One encoder's switch and rotation work perfectly in test mode, but it doesn't sense touch. I've done the diagnostic as suggested by Eddie and confirmed touching one of the larger solder mounts does not register a touch so it must be the IC. I'd like to confirm the IC needed, but it appears to be different than the one used in the MC Mix (Atmel QT113B):
Microchip PIC 12F5091
Can anyone please confirm if this the correct one to replace?
Thanks in advance!
  #32
Old 04-14-2019, 12:06 PM
MoPro's Avatar
MoPro MoPro is offline
I could be wrong, because maybe it should be that way, but resistor "R164" from your picture appears to be missing.... I'd check for loose parts rattling around the chassis.
Al
Computer Asus P9X79 Deluxe | Intel i7 3930k | 32 Gig Ram | Intel 520 SSD's | 2T Caviar Black
Software Win 7 Ultimate (64bit) | Cubase Pro 9.5.41 (64bit) | WaveLab 9.5.25 (64bit) | HALion 6 (64bit)
Hardware RME FireFace's UFX / 800 | MOTU MTP AV USB | Avid Artist Series: Control, Mix, and Transport | EuControl ver. 18.3
  #33
Old 04-14-2019, 12:16 PM
Thank you for the reply! I just took a look at the other encoder circuit sections and they all have the resistor unpopulated. I've attached a more complete picture of all 4 encoder sections. So, good observation, but it looks like it's supposed to be that way...
Al
  #34
Old 04-14-2019, 01:08 PM
MoPro's Avatar
Originally Posted by LesPaulGtr View Post
Thank you for the reply....So, good observation, but it looks like it's supposed to be that way...
Okay...fair enough.
The joints for the Diode (D93)look a little suspect also, as do some of the other work... pitting in the joints themselves. Do you know if anyone else has been tinkering with this unit?
I only mention it because you may have to just touch-up some of those joints.
Al
  #35
Old 04-14-2019, 04:45 PM
Hmm, good question. I'm not sure if anyone else worked on the unit, but a lot of the joints look the same. Thanks, I'll reflow those joints to be on the safe side before replacing the IC. In doing some research, it seems like while the Artist Mix uses ICs that had dedicated touch sensor pins, the MC control is using a fairly generic 8-bit PIC and having it's ADC to sense capacitive touch.
Thanks!
Okay...fair enough.
Al
  #36
Old 04-15-2019, 06:34 AM
MoPro's Avatar
The MC control is using a fairly generic 8-bit PIC and having it's ADC to sense capacitive touch.
Thanks!
Okay... I've been looking at the data sheet for that particular micro controller, and judging from the 12F509i footprint, it doesn't appear to have an A to D converter.
Just picking your brain here, and sorry for the questions... I know you're looking for answers!
If you buy a replacement PIC, how do you know it will be programmed to the spec of the Artist Control?
Even if you had a copy of MP-Lab, and a PIC programming setup... where would you get the program to flash to the PIC in the first place?
I don't know, but that is starting to sound like something proprietary from AVID... in addition to the PIC itself.
But , then again i'm just speculating here, and like you... just looking for answers.
Al
  #37
Old 04-15-2019, 06:55 AM
Thanks @MoPro. That is a REALLY good point which I didn't think of until now. I guess someone from Avid would need to chime in, but short of taking another good IC and cloning it (if copy protection is not enabled), this repair would be impossible for me to do. If I don't hear from Avid, I'll cut my losses and return to the seller.
Thanks again
  #38
Old 07-03-2019, 02:18 AM
polycorn polycorn is offline
Thanks again
Hi, I don't know if you worked out your problem but I have a broken Artist Mix. I could send you two of those IC's (one to use and one spare) if you want.
  #39
Old 09-16-2022, 12:46 PM
dshonk dshonk is offline
I found this thread with component info fore the Artist Mix. I am hoping someone may be able to help.
I picked up a damaged Artist Mix that doesn't power up. In opening the unit, you can see it looks like it took a power surge (see image)
That damaged area is the reverse side of the power switch. It looks like its 4 solder pads to swap it out. I am just not sure how to go about finding a replacement.
Anybody know the part or have recommendations?
Thanks,
Dave
  #40
Old 09-16-2022, 12:55 PM
EddieJones's Avatar
Thanks,
Dave
No this is the component(Inductor) next to it. There's a separate thread on how to fix that. https://duc.avid.com/showthread.php?...t=choke&page=3
Avid Artist Control Encoders - Can we make them linear? jvining Artist Series 4 10-11-2014 01:54 PM
Rotary Encoders randomly going into write colinweeks ICON & C|24 4 05-17-2009 07:59 PM
Are the rotary encoders touch-sensitive... Stig Eliassen ICON & C|24 2 07-31-2008 08:53 AM
Velocity sensitive vs fixed mode encoders. mixboy bob ProControl, Control|24, Command|8 4 10-08-2006 04:19 PM
Difference between motion sensitive and touch sensitive faders? bp78 Pro Tools TDM Systems (Mac) 7 07-03-2002 09:27 AM
