Old 09-08-2010, 10:47 AM
bkee bkee is offline
Default Pro Tools LE 8 on Mac Mini Server
Is it possible to run Pro Tools LE 8 on a 2010 Mac Mini Server with Snow Leopard Server OS? I want to use the Mac Mini Server as a stand-alone machine, not networked. If possible I would be interested in using one of the internal 7200rpm drives to run the application and the other to save the audio.
Many thanks,
Bek.
Old 09-08-2010, 10:49 AM
Dism Dism is offline
Default Re: Pro Tools LE 8 on Mac Mini Server
Originally Posted by bkee View Post
Many thanks,
Bek.
I'm 99% sure you need regular SL to run Pro Tools... but it's not at all hard to get a hold of, and it should install without any dramas.
D
a n t h e I n c r e d i b l e S o u n d M a n
"Svetlana" v1 - 4.2GHz i7, 16GB RAM, OSX 10.7.4
Liquid Saffire 56 - PT10.2 - BFD2, VCC, Duende Native, Play 3.0
_C U R R E N T-D V E R B-S C O R E:515
Old 09-08-2010, 02:37 PM
The Dougfather The Dougfather is offline
You can resize partitions on SL no probs, worst case split the main drive in to two partitions assuming you need to retain SLS, install regular SL for $30 and install Pro Tools and you should be good to go.
I'm currently running Leopard and SL on my MBP just while i make sure SL doesn't break compatibility with any of my existing apps/plugs etc.
iMac i5 2.8GHz, Macbook Pro 2.4GHz, Pro Tools 10/11, MOTU 828mk2, Presonus Digimax FS, Presonus Firestudio Project, TC Konnekt 24D
iCON Photography
2011 Mac Mini Server himynameisdustin macOS 6 03-11-2014 03:00 PM
Mac Mini, Mac Mini Server, or iMac? fretcruiser macOS 5 06-17-2012 10:37 PM
Mac Mini Server as VE Pro Slave? mdvirtual Virtual Instruments 2 11-18-2010 10:58 AM
Files transfered server-server relay still downloaded from remote server Phill Barrett Aspera DigiDelivery 1 03-19-2010 01:58 AM
New Apple Mac Mini Server dr sound Post - Surround - Video 2 10-21-2009 02:34 PM
