  #21
Old 02-16-2013, 10:02 AM
nst7 nst7 is offline
Default Re: Anyone figure out how to play system sounds through HD Omni?
Did you follow the instructions in my earlier post about setting this up in the mixer tab? Also, you may need to configure things in the audio midi setup of the Mac to output digitally. And, if you are using an optical cable, you may need to set the Omni's Spidf setting to optical (this will also prevent you from using Adat).
  #22
Old 02-23-2013, 09:31 AM
Teolin Teolin is offline
Is there any reason this same routing configuration wouldn't work on a Win 7 computer with an optical out?
Pro Tools 12.4
HDN, PCIe, Omni & Digi 192
ASUS Sabertooth, Intel i7 3820 3.6Ghz
32 GB 1600Mhz Corsair RAM
SSD 500GB Samsung
WIN 10 64bit
  #23
Old 02-28-2013, 08:31 PM
K Roche's Avatar
K Roche K Roche is offline
Originally Posted by rockin' daddy View Post
I'm still a little confused about using the Omni to play back iTunes.
I spoke with Avid Technical Support and was advised the Omni/Thunderbolt configuration will not play Pro Tools and iTunes simultaneously. iTunes will play through the Omni with Core Audio Manager software open provided Pro Tools is NOT running.
Will the suggestions provided earlier in the thread... like connecting the headphone out of my iMac to the spdif "in" of the Omni...allow me to have Pro Tools running and then open iTunes and have it play through the Omni simultaneously?
When Pro Tools is open, I noticed the volume icon on the upper right hand menu bar is grayed out, and although iTunes will open, it won't play. I tried connecting a spdif cable from the Headphone out to the Omni SPDIF "in", but nothing changed. What am i missing?
I am new to the HD Thunderbolt/Omni bundle so be gentle!
I'm using:
PT 10.3.3 (HD Native)
Apple iMac: iMac 3.4GHz Quad-Core Intel Core i7 27"
RAM: 32 GB
Operating System: Apple Mac OS X 10.8 (Mountain Lion)
So I am guessing the reason to not just quit PT when you want to listen to Itunes, is to be able to quickly compare your current mix with some reference mix? Because other than that, If you just quit PT, you can listen to anything from your connected computer thru your system with no problems.
System :
Studio - Avid Carbon interface , PT Ultimate 2023.12 Mid 2020 (intel) iMac 27" Ventura 13.2 .1
Mobile - 2021 14 " MBP M1 Pro PT Ultimate 2024.3.0 --Sonoma 14.4
Enjoy the Journey
.... Kev...
  #24
Old 02-28-2013, 08:51 PM
agershon agershon is offline
Default Anyone figure out how to play system sounds through HD Omni?
Or import the mp3 into your session. You don't even have to import. Just preview the audio from the import screen.
PT10 HD Native Thunderbolt w/ HD Omni
MacBook Pro - Core i7, 8G RAM, 10.8.4
  #25
Old 03-02-2013, 05:13 AM
cananball cananball is offline
I'm using:
RAM: 32 GB
The standalone mixer function of the Omni work independently of Core Audio. Inputs that are assigned in the mixer tab in the Pro Tools Hardware Setup window will play into the Omni's inputs and directly out to the Monitors, regardless of Pro tools being open or not.
Ken Wilkinson
http://kenwilkinson.tv
Pro Tools 10.3.9 HDN | HD Omni | Digi Command 8 | Artist Transport | Digi Surround Panner | Blackmagic Intensity Pro | JBL LSR4328 5.1
2.26GHz 8 Core Nehelam 8GB Ram OSX 10.8.5
  #26
Old 03-02-2013, 06:00 AM
groundcontrol's Avatar
groundcontrol groundcontrol is offline
Why wouldn't you rather preview them in the workspace?
Can you please send yourself over fiber to go spam some other forum?
Darryl Ramm
  #27
Old 03-02-2013, 07:40 AM
Teolin,
I'm not a Windows guy, but I'm guessing you would just need the ASIO 4 all driver to use the optical out in Windows.
  #28
Old 03-29-2013, 02:49 PM
While we're at it ... wondering if anyone has this issue:
While I'm listening to Spotify, every minute or two so I get a stutter in the music. Quick, like 1/2 second but it stutters in place like two or three ticks and then moves on. Weird.
Omni says 48k s/r. Any ideas?
  #29
Old 03-29-2013, 02:55 PM
It's called the Internet...
Does this happen with other audio sources? Does it happen when playing back through the computer's local audio device?
Darryl
  #30
Old 03-29-2013, 02:56 PM
Nope. When I listen with headphones plugged right into the MBP it's fine. It's not a buffering thing.
System sounds don't play thru Mbox2 Pro in W7 Pro w/ PT 8.0.5 le scott_nikki1216 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 4 12-28-2011 02:11 PM
Pro TOols playback is OK, system sounds and other sounds won't play bimple Windows 1 08-24-2011 05:14 PM
Did Anybody Ever Figure out How to Get Their Mac to Play out of the 003 Console? fooloof 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 09-18-2009 07:09 PM
I cant figure out why it wont play Mark Madness 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 01-26-2009 05:50 AM
can't play XP system sounds or iTunes thru Mbox Bassman3141 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 4 12-28-2005 04:06 PM
