003rack+win7-64bit PC+digi asio driver = midi input (5pin) problem!
First my setup:
- digi003rack - Windows 7 Ultimate-64bit + sp1 PC-assembled (asus P7P55D-E + i5-760 + 4gb ddr3-1600 dualch. + hd SATA3 6Gb/s + ati hd 5450) - keyboard 1 : roland sh201 usb midi - keyboard 2: generic master keyboard classic old midi 5 pin I have a strange problem with my generic master keyboard with classic midi (5 pin) and digi003 midi input + cubase5 + digi asio driver. if I open a new empty project, MIDI input works, but if I change the project or change the buffer size by digi asio control panel, immediately after the midi input disappears, it stops working! I have to close and reopen the cubase program, which is absurd, that I never happened when I used the digi003 with winxp pro sp3 ... This problem, however, is not using the other keyboard that has the usb midi (roland sh201) and this works fine if I change my cubase project and if I change the buffer size on the digi asio control panel. I tested the new digi003rack asio drivers for win7-64bit... - "002 and 003 Rack Drivers v9.0.2.65" - "002 and 003 Rack Drivers v9.0" - and the previous version v.8.0.4b. none of these drivers solve the problem with the '5-pin MIDI input. (003rack+windows xp pro with sp3 all right! no problems! audio, midi, everythings ok) i think that the problem of digi003 midi input (5-pin) is related to the win7 64bit and the new ASIO digidesign-avid driver if someone uses PC with a keyboard (MIDI 5-pin) connected to digi003 + win7 64bit + cubase 5 (or protools 8/9) without any problems, Please help me to follow in his footsteps and system config (drivers version, installation procedures) Please! i need help! Thanks!! |
003rack + windows7 64bit = asio driver problems | johnut | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 8 | 05-25-2011 06:28 AM |
ASIO Drivers for Pro Tools 9 in win7 64bit DO NOT WORK | cdmstudios | Windows | 18 | 04-11-2011 03:24 PM |
MBox2 Mini: ASIO Troubles with Win7 64bit!! | dRead | Windows | 8 | 04-04-2011 06:13 AM |
DIGI ASIO DRIVER PROBLEM WITH FL 8 "Not Enough ASIO output channels available. | scottthafoo | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 14 | 04-19-2010 01:45 PM |
midi problem with digi 003rack | Sonnao | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 4 | 07-28-2009 08:58 AM |
