  #21
Old 01-13-2014, 04:10 AM
mgoorevich's Avatar
mgoorevich mgoorevich is offline
Default Re: Video Engine in PT11.1
Ok. It is huge for me. Please read huge as unacceptable - not long. Sorry english is not my native language;-)
Michael Goorevich
Sound Designer
/ mixer
www.goorevich.com
PT HD⎪N v2024.3 Ultimate ● macOS Ventura 13.6.3
MacPro 7.1 (2019) 3.2GHz Intel Xeon W 16-Core ● 96 GB RAM
MTRX Studio + DADman 5.7.0.1 + MOM ● Sync HD ● AJA Kona LHi referenced by AJA GEN10 ● D-Command ES24
  #22
Old 01-16-2014, 03:19 PM
Brandonx1 Brandonx1 is offline
Originally Posted by BobbyDazzler View Post
So are you getting good video results when dragging sounds on the timeline? Mine is spitting out about 3 frames/second. Scrubbing is about 10fps (This is out of the BM HDMI out).
I will say PT 11 video doesn't have as many frames in scrub as PT 10 did but I just don't need that, I guess. I normally find the rough spot I need to find and then go frame by frame. Scrubbing is the same. I never scrub faster then 10 frames a sec, which I think PT displays. If I move fast through the timeline, I see jumps. The jumps don't interupt my workflow.
As of 11.1.1 PT seems almost as fast as 10. Granted, I do get a microsecond of delay on play. Reminds me of PT 9.
Brandon Howlett
Vibe Audio Post, Inc.
Re-recording Mixer
Custom Build CPU, HDX 1, Omni, 192 I/O Digital
S6 M10 24 fader
Satellite Mac Pro, HDNative, 192 I/0
Black Magic HD Extreme
  #23
Old 01-17-2014, 09:41 AM
Over here it's definitely better than before but significantly worse than under 10. For me the main issue is selecting across a section and nudging with +- which still feels sluggish.
So, better but still room for improvement.
Frank.
  #24
Old 01-19-2014, 09:21 AM
mgoorevich's Avatar
Here is the latency issue in playback I experience with PT 11.1.1
I comment on the video what I am doing.
Michael Goorevich
Sound Designer
/ mixer
www.goorevich.com
  #25
Old 01-20-2014, 04:08 AM
paulo m's Avatar
paulo m paulo m is offline
Hi Michael, seems that you made your movie with a smartphone or tablet.
Since you´re on a MAC, you can use QT player to record the screen activity instead much better results and easier.
Regards,
Paulo M
MAC Studio MAX M1_64 GB RAM_1TB SSD_MAC OS Ventura
Protools Studio 2024.3
  #26
Old 01-20-2014, 05:10 AM
mgoorevich's Avatar
Hi Paulo,
True. But I wanted to record also the TV and myself pressing spacebar…and also to record my voice comments.
Yes I was lazy to connect the mic and make from it a film production…although I could.
Don't you see the problem displaying on the video clear enough?
Michael Goorevich
Sound Designer
/ mixer
www.goorevich.com
  #27
Old 01-20-2014, 08:34 AM
Originally Posted by mgoorevich View Post
That delay is about 100 times greater than what I get. What are your system specs? Drive the video is on's specs? Video codec?
I can make PT playback that slow as well if I set up PT with slow drives, a slow computer, ect.....
Brandon Howlett
Re-recording Mixer
S6 M10 24 fader
  #28
Old 01-20-2014, 08:39 AM
tamasdragon tamasdragon is offline
That it too slow. I don't experience this, so there's must be a definite reason which we should find (I know Avid should find this, but maybe we can help).
The strange thing is I don't have that delay anywhere, not a single machine which I use exhibit this problem. Not even my laptop.
my blog:Tamas Dragon
  #29
Old 01-20-2014, 11:43 AM
garnoil garnoil is offline
I also get a shorter delay than what you are showing on your youtube video but..I have 260 audio tracks playing, massive plugins, including 24 instances of CEDAR, 12 reverbs including native IRLs, as well as DSP Revibes, all my tracks have Avid Strip DSP, and I am recording 6 X 5.1 stems for DX only, SFX only, music only, ltrt only, etc.My HDX is alsmost full and my computer, which is only an 8 core at 2.26 Ghz and about 8 years old, is almost chocking. I am also playing a 90 minute feature film with either Avid codec or Pro-Res HD at 1920X1080 and I am driving 4 monitors (2 on my desktop, and another s from my BM card). . My CPU is fully used, I am pushing my computer to the max and my start up delay is about 1/3 of what you are showing. I think something may be wrong with your set up.
  #30
Old 01-20-2014, 11:56 AM
mgoorevich's Avatar
Well, I would like to know as well whats wrong!
And why my PT HD 10.3.8 plaing a heavy session with 250 tracks and pushing to the limit my system (plugins, 5.1 stems e.t.c) still has 0 delay with the video playback. Same file. Same everything.
My specs are in my signature. I use DNxHD 36 1920x1080. 24 or 25 fps. Same happens even with DV codec.
Something suspicious I have with Sync Offset in PT11 though. While in PT 10 I have 11 quarter frames offset in PT 11 it is (yes, minus) -3 quarter frames. Measured with Syncheck 2 with a new battery..
I have never had that absence of answer for myself since PT5. But the good thing is that I seem to be the only one who has that long delay.
My dedicated Video only drive is 1T Caviar Black SATA internal drive.
Dedicated Audio drive is another 1T caviar Black SATA internal.
System only on a separate SATA 500 GB drive.
And again , working on a monster session in 10.3.8 is flawless and a pleasure with the same session.
Michael Goorevich
Sound Designer
/ mixer
www.goorevich.com
HTML code is On
Boot Screen "Not Recognized Video Hardware Connected", "video engine failed to init bcrichguitar macOS 3 04-01-2012 09:10 AM
Video engine Bender 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 09-22-2010 06:30 PM
How to disable Video Engine Esus Pro Tools TDM Systems (Mac) 2 06-02-2010 02:21 PM
How do I get rid of the Video Engine? notr2d2 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 12-31-2009 09:51 AM
Where's the Video Engine? admix Post - Surround - Video 4 05-02-2008 04:51 PM
