Old 10-07-2013, 08:21 PM
Ryan Masecar Ryan Masecar is offline
Default Replacing a Fader in Command 8
Hey guys,
This is my first post on the DUC. I've lurked for a while, but I finally need some help: I need the model number of the faders used on the Command 8 so I can replace mine.
I hooked it up for the first time in about a month, after moving back to NC after living in Boston for several years, and my third fader wasn't calibrated right - it moved much faster than the other seven, and it seemed to only offer a range from ~100 to ~900, instead of the usual 0 to 1093. I took it out and looked over it with a multimeter, which showed me that one of the pins was no longer giving me anything at all. So I took the fader completely apart to find that one of the tracks has a break in it somewhere, which makes it totally useless as far as I can tell.
I know it's an Alps, and that it's a 100mm touch-sensitive motorized fader, and the closest I can find to what I have without a definite part number is RSAON11M9.
Surely there must be someone on here who's had to do this before. Any help would be appreciated.
Thanks
- Ryan
Old 10-09-2013, 08:27 AM
Top Jimmy's Avatar
Default Re: Replacing a Fader in Command 8
I would suggest contacting a repair center for the part you need.
http://avid.force.com/pkb/articles/en_US/faq/en210711
Parroted by me & Tapasquawk
James Cadwallader
Fs: 24 fader d-command with x-mon T Marks Buy & Sell 4 09-24-2013 03:27 PM
D-Command ES + Fader Madule Fader Problems FedericoF ICON & C|24 11 05-24-2013 04:27 PM
replacing fader cap on digi002 boleary2 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 06-18-2009 08:55 AM
40 fader D-Command! RichN ICON & C|24 8 10-22-2008 04:50 PM
Replacing Control 24 Fader Matt82au ICON & C|24 1 05-29-2008 01:39 PM
