Omni internal mixer not working properly
Hi everyone,
I've been having a weird issue with the internal mixer. I've hooked up the computer's line out to Analog Inputs 3-4 on the Omni, routed those to Monitors and Headphones, all working fine. Occasionally though I can't hear anything coming to Inputs 3-4 unless I keep my Hardware Setup window open. Doesn't matter if I open this window from Pro Tools or the Core manager, the situation is the same: the interface only plays sound while the window is open. If I check signals on the interface itself (changing Meters to show In/Out) it does show signal coming in. As soon as the windows closes, the interface still shows signal coming in, but no sound coming out. Any way to fix this? Cheers |
Re: Omni internal mixer not working properly
There's a little checkbox underneath the hardware mixer graphic. Now I can't remember exactly what it says on it, but it has the word mutes in it somewhere. Anyway, try checking it, or unchecking it if it's already checked.
Wow it'll be a miracle if that advice helps ANYONE...but I did have this issue and that's how I fixed it. Jack |
Hey Jack,
Yeah, I know what's that mute thing, it's to automatically (which is what I set to, but could be manual) mute the direct signal (in my case, what comes from the onboard Line Out) upon enabling Input Monitoring in those same Inputs. Anyways, the problem is now gone after restarting everything (computer and interface), but I'm sure it will happen again as usual. I was on firmware v2.6 and it happened a few times, upgraded to v2.10 hoping to fix it but it clearly didn't. I'll try switching the "mute thing" in and out if it happens next time, but I'd appreciate if anyone else had other suggestions! Cheers |
Omni persistent mixer with 5.1 input | dj_grimmace | Post - Surround - Video | 23 | 01-28-2015 05:08 AM |
OMNI Mixer "Mutes" function not working | mu-tron-kid | Pro Tools HDX & HD Native Systems (Mac) | 1 | 01-29-2014 06:43 PM |
Not working properly | trife | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 9 | 09-10-2008 08:40 AM |
TC/E not working properly. | twigstickley | Pro Tools TDM Systems (Mac) | 2 | 03-22-2005 10:12 AM |
PT not working properly | chainboy | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 2 | 04-21-2004 01:11 PM |
