Old 06-19-2012, 10:49 AM
MrBibidy MrBibidy is offline
Default URGENT HELP NEEDED, Clocking cause assertion errors
So I'm getting this error:
"Volumes/Development/ws.Ludwig/AlturaPorts/DFW/MacBuild/../Views/UMenu.MacOS.mm", line 1350.
I know its related to the playback engine and I have repeatedly tried every normal troubleshooting remedy including holding N when starting.
The issues arrises when I attempt to run at 96Khz. I'm using an Echo Audio AudioFire12 and an AudioFire8 clocked externally to an Apogee Rosetta 200. On Pro Tools 10.2. MacPro 2x2.8 GHz Quad-Core Intel Xeon, 4GB Ram, OSX 10.7.4
Pro Tools starts fine if Im running at 48khz or i shut off my interfaces and run on the Built-In Output. Then if I attempt to turn my interfaces on or if they are already on and I switch my playback engine to them Pro Tools hangs and doesn't recover.
Also, when I am experiencing this issue sometimes pro tools will hang on startup when as it gets to a certain plugin to load, lately its been my UAD2 1176, previously it was RND Inspector.
Why does pro tools have to be so difficult? Does anyone have a solution? I would specifically like Avid to chime in here if they are reading. Its not and issue with the Echo devises. Pro Tools attempts to reset the clock on my interfaces and thats when everything goes to crap. I know this cause ProTools can reset my AudioFire12 but the AudioFire8 maintains its settings.
James Hurley,
Int'l Freelance Producer & Mix Engineer
http://www.Abravemix.com
URGENT! Assertion in "/Volumes/ etc etc line 286...wtf?! TonyMcHugh Pro Tools 10 6 09-24-2013 10:12 AM
Urgent - Clocking my preamp to 96 I/O MikeX Pro Tools TDM Systems (Win) 2 11-09-2010 06:08 PM
More errors when clocking from external AD/DA...DIGI PLS HLP req06 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 8 05-28-2008 10:47 AM
Clocking errors , need help!! JasonAaronAdams 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 1 12-17-2004 06:46 AM
USD needed for external clocking ??? MMazurek Pro Tools TDM Systems (Mac) 3 05-05-2001 03:26 PM
